6.0 bulletproofing and some other minor changes
I assume you're studding it? Was there a HG problem before teardown? Did you see the old gaskets? #8 looks like it was starting to let go, but hard to tell from pics. Any unusual, heavy patterns on the piston tops? A light star isn't uncommon. What's in the VR gasket package? Do you like Mountain Dew? LOL
If the HG's will be VR please do some research before letting them proceed with installing them. If you are planning on adding any power, factory Ford MLS HG's have proven over, and over that they will hold up better than any aftermarket stock type gasket. It is a big deal, because you don't want to have to do this again for a long time.
The body off stud job on my truck was performed in 2008. I run the heaviest tunes Eric can write, and have put over 100#'s of nitrous through the motor. Mine are still holding strong.
I haven't checked prices recently, but a quick search showed about $300/pair from Ed at Ficmrepair.com. Install is no different, and labor wouldn't change if they haven't put the heads back on.
Fwiw, I just rebuilt my wife's 05 Ex, injector tip broke off, anyway some things to think about, I would go with new crank sensors and cam sensors, make sure you have an updated STC if you have a 05 engine, updated turbo oil feed line and update return tube, I elected to remove the engine from the chassis, I wanted new lifters, new bed plate gaskets and I needed to clean up the one hole, there has been some cases of lifters collapsing, I replaced all the lifters but you have to remove the rear cover I believe, only 200.00 more, happened to my best friend on an 04, there's lots of extras to do to these, sounds like you are on somewhat of a budget, I get that but do it all and do it right, there will be no other time when it will cheaper. I know it's expensive, I spent over 5 grand in parts and I didn't need a turbo and did all the work myself. Had both heads serfaced and valves all done. Like I sad it will never be cheaper than it is today!
Head gaskets:
6.0 Head gasket kits
Head gaskets:
Head gaskets:
Head gaskets:
I do appreciate everyones advice and I am looking forward to getting the rig back on the road, many thousands of dollars poorer no thanks to the likes of you!
I won't change my opinion on the HGs because of a single, short video.
The Black Onyx 6.0 gaskets that VR used to offer have a less than stellar reputation after a high level of reported failures. Who knows how many of those failures were due to other factors, but I wouldn't take the chance with VRs second attempt at doing it right.
It's your truck, and your money. If the shop stands behind it, and you are comfortable, that's what matters.
Now where are the progress pics?
#28
#29
#30
It fits, but pinstriping is inevitable.
For sure. I'll be up there a lot this year.
