Mystery white smoke from exhaust
Good Evening Y'all, My name is Kyle and have a 1991 Ford F350 4x4 XLT Lariat 7.3 IDI diesel with ATS 093 Turbo kit. I replaced the following:
New performance injectors from R&D IDI Performance, custom K&N intake, CDR Valve, 3" downpipe into 4" straight pipe with turn out before rear tire, oil/filter, Radiator and coolant and Gloplugs.
I just put the injectors in and drove 45 miles, the MPG went from 9 to 13.5 and sounds better but still smokes. Below is a video of it smoking. During the freeway drive, EGT's were 300-600 and water temp 175 degrees. I am new to diesels but a decent wrencher. Please advise on what else to look into.
Details: Single Cab, Turbo wastegate is set at 7psi, 5 speed manual, 6 inch lift, tires are 325x70R17, clutch replaced 2k ago, ATS gauge cluster (Turbo boost, coolant temp and oil pressure at turbo), EGT gauge.
Truck has 143K and believe the IP has never been changed. Just maxed the IP and still same problem but now black smoke when floored. EGT probe is on the exhaust side of the turbo because i read thats the best place for it. Engine was warm and does the same while driving too. Coolant is perfect, now mixing and exhaust doesnt really smell bad or good. Awesome, thanks for the inputs, going to do more research on timing.
Hmm one wonders why you would change injectors and not IP? Common knowledge around this place is that they need to be replaced at the same time. If your IP really has 143k on it, it is definitely nearing the end of it's service life. You could be chasing your rear end all over the place trying to fix what may end up being just a plain old wore-out pump.....
Little ouch on the wallet but well worth it....
JM2CW
JM2CW
OldSchool68
02-17-2024 02:45 PM
89IHDiesel
08-26-2014 04:46 PM
