How does Cyclops "no start" work?
I have not looked into it, but if the starter relay is the same as the IDM, then you could replace that instead and it would probably work. I kind of like the idea of the potential thief not realizing that it won't start. This may give me a chance to hear it, or frustrate them enough to just leave it.
If the starter was disabled, they may have time and the initiative to look around a bit.
Added this to my list of must have mods. I will definitely pick one up before we go cross country this summer.
There are different codes. I ordered one for me and one for the wife, the fobs are not interchangeable. Several of the locals did a group buy on these years ago. I don't know of any fobs that would start someone else's truck.
You can push the button prior to starting even if the key is not in the ignition yet. It gives you a while to start, like a minute or two I think. I haven't tried it while still outside the truck, I usually press the button just before or just after I insert the key.
Are you SURE you aren't mistaking it for the PCM's power relay? That has what you are describing, like the fuel pump.
Pop
So... with the ongoing conversation re Cyclops... If it's as easy as us keeping a normal relay available as a backup in case the theft-preventing relay stops working, is it unreasonable to think that a thief might just have such a spare relay as well? Especially if the PSD is being specifically targeted? After all, the relay is small enough and cheap enough to keep as a "just-in-case" tool for those with unlawful tendenecies.
This is, and other scenarios as well, is what keeps me coming back to taking Pop's approach with a hidden mag switch in some out-of-the-way or otherwise obtuse location.
#28
#30
Most alarm systems have a starter disable built into the system. Starter doesn't crank and they know what to look for. Starter does crank and the truck won't start, they eventually give up because more folks will look over at a non-starting vehicle that is just cranking than they will at one with the alarm horn sounding.
