Oil Drain Plug
Old 04-08-2015, 09:53 PM
wiskeyVI's Avatar
wiskeyVI
wiskeyVI is offline
Oil Drain Plug
Does anybody know what size the drain plug is on the 5.4?
I'd like to get a Fumoto style quick drain plug before I do an oil change.
Or, does anybody here have a source for said plug??
Thxs
Old 04-09-2015, 02:26 AM
wiskeyVI's Avatar
wiskeyVI
wiskeyVI is offline
I found some.
Old 04-09-2015, 07:40 AM
Jon Wagner's Avatar
Jon Wagner
Jon Wagner is offline
Do you mean these?
Fumoto Valve | Qwik Valve™
I haven't tried them, but I have been thinking about it.
Old 04-09-2015, 07:43 AM
wiskeyVI's Avatar
wiskeyVI
wiskeyVI is offline
Those be them!
Used them on my last two rigs and really appretiated them!
Old 04-11-2015, 08:34 AM
JWA's Avatar
JWA
JWA is offline
Received 1,393 Likes on 1,102 Posts
When I was looking for something similar---mostly to avoid oil spills in my drive way ---I found these: Unique Truck Equipment
While the Fumoto stuff is nice I didn't care for the potential risk some road hazard shearing it off and disabling the van for the moment. The Quick-Changers present a much lower profile and exposure to such things, they've very close to the same size as the factory drain plugs.
I liked them so much also installed one in my 4R70W trans pan too.
All IMHO ya understand............
Old 04-11-2015, 04:20 PM
wiskeyVI's Avatar
wiskeyVI
wiskeyVI is offline
I've not seen those before.
Very interesting!
Is it like an air hose connection?
Old 04-17-2015, 06:14 AM
JWA's Avatar
JWA
JWA is offline
Very interesting!
Not so much----its just a "dry break" connection, the type used in aviation and hydraulic systems. When apart the pan-mounted part doesn't allow flow even with the protective cap removed. Only when the mating drain part is threaded onto the pan part does flow begin.
I like this over the Fumoto as its in my mind the lower profile along with the manner in which draining is accomplished makes for a safer replacement system for less messy driveway oil changes.
Old 04-22-2015, 10:55 AM
wiskeyVI's Avatar
wiskeyVI
wiskeyVI is offline
Well, I too was not like king the positioning of the Fumoto valve.
It just didn't sit well. The ones in my last two trucks hung straight out of the bottom and I was comfortable with them. This one, not so much.
I may try the other next oil change.
littlegreenford
Modular V8 (4.6L, 5.4L)
12-14-2008 11:29 AM
Mudder
Oil & Lubrication
01-12-2006 06:16 AM
clintbonnie
01-04-2006 08:20 PM
marvinlong
04-01-2005 09:50 PM
Quick Reply: Oil Drain Plug
