1989 f150 sputtering issue
i have an 89 f150 5.0. engine is not original to the truck was in there when i got it recently. the truck ran fine with a small exhaust manifold leak. i replaced the o2 sensor when i crawled under to check it and it broke off. a few days later i ran the truck to the store and back ran as good as usual. i went to use it a few hours later and it had a miss and sputters pulling out the drive and gets worse the faster i go. i replaced cap, rotor, plugs, wires, did a fuel pressure test and it was at 40lbs. but replaced the fuel filter and regulator anyway. also replaced the icm on the distributor on advice from advance. no codes except the egr but that was after i pulled the egr sensor and played with it. i used a piece of beer can to block the egr to intake and did not make a difference either. the cat is removed this is a farm vehicle and does not require any emissions. any help would be appreciated. im a blonde not a dumb one and done everything i can to figure this out. maybe the low pressure fuel pump? on a second topic can i remove all the egr and smog and the truck still run as it should? thanks all
Pull the codes, you should get something even if it is an OK code, this is to make sure the PCM is working. For the fuel pressure...put your gauge on the rail and start the motor, check the pressure. Turn off motor, pull the vacuum line from the fuel pressure regulator and start the motor. Did the pressure go up?
If you get a PIP code then you need to replace the stator in the distributor. The PIP sensor is mounted on the stator.
Do not remove the battery cable as it can cause more problems and set another code.
Only remove the battery cable if you replace a sensor and then clear the power code with the STI wire when the CEL starts to flash.
The hall effect PIP sensor is a digital output device located within the distributor. A rotary vane cup, used to trigger the hall sensor, is mounted on the shaft of the distributor and is made of a ferrous metal. When the window of a cup is in the air gap between the hall device and the permanent magnet, a magnetic flux field is completed from the magnet through the hall device and back to the magnet. This condition results in a low (0 volts) output signal. As the distributor shaft turns, a tooth on the cup will move into the air gap. The magnetic field will be shunted by the tooth, preventing it from reaching the Hall device, and the output signal will change from a low to a high (VBAT).
I did not say damage I said problems for both the running and the poor person that is trying to find out what is wrong.
If you have a bad sensor and the computer reverted back to a set valve to run the engine and you remove the battery cable then the computer may read a bad sensor and now use its value and the engine might not even start or may run worse. Also it will set a memory failure code and someone not up on it may change out the computer because that is what the code says to do. Not to mention that all the Ford shop manuals say not to do it. If you are going to change out the battery out you can put a new 9volt battery in the lighter plug to maintain the codes and memory while the battery is being changed.
You also have to drive the truck about 10 miles to get the computer to read all of the sensors again and act right.
I have also posted this many times.
