Couple questions about my engine
Old 04-08-2015, 01:06 AM
91Fbody's Avatar
91Fbody
91Fbody is offline
Question Couple questions about my engine
I've found some conflicting info on which engine I have.
Serial decode says the 239. Wikipedia says the 239 was replaced in 1955. I've read where grabbing the stamping on the engine will suffice. Others say that isn't always accurate.
If I can't verify it, how will this affect part shopping(main item is fuel pump right now)?
Old 04-08-2015, 06:22 AM
Harrier's Avatar
Harrier
Harrier is offline
The 239 Y-block was used through 1955.
The 239 had EBV Heads and block.
Here is some info on casting numbers:
TECHNICAL
Y
Old 04-08-2015, 04:46 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Serial decode says the 239. Wikipedia says the 239 was replaced in 1955 Ford Passenger Cars only (with the 272).
Wiki Wiki info should be taken with a grain of salt, as some of their info is either misleading or BS!
OHV 239: 1954 Ford Passenger Cars & 1954/55 F100/700.
Gregruk
01-08-2012 11:29 AM
52 and 76
15
07-08-2011 04:54 PM
yellow truck
01-27-2008 03:46 PM
babyfacejack
07-26-2006 04:00 PM
Craig
22
06-21-2000 05:03 PM
Quick Reply: Couple questions about my engine
