cruising EGT's
cruising EGT's
Just curious what some of you are seeing for EGT's while cruising at 65? Bone stock my truck used to run 700-720 while cruising 65 but after all the upgrades in my sig, now I am closer to 800-825 while cruising. I don't think I need to worry about it because under WOT, I can't break 1200* but I was just curious why my cruising EGT's would be higher than before. Thanks!
Thanks for the replies! Yes, along with the 4" lift came 35" Toyo AT2 tires. Today with warmer weather, my EGT's were in around 875-900* while cruising 65. I talked to a buddy of mine with 155/30 injectors and a hot tune, leveling kit, and 35" tires and he runs around 800* but he said he rarely sees over 950* during his normal driving routing.
I on the other hand almost always break 1050* while accelerating to highway speed. I truly think there must be a problem, but I cant find it!
I have tried a turbo boost leak detector and only found a small leak in the MAF hose which I soon replaced.
I let the truck cool down then had a buddy start it and rev it up while I felt for exhaust leaks around the up-pipes and y-pipe but felt no leaks and saw now signs of soot anywhere. I am at a loss at to what the problem could be!
builttoughf350
6.7L Power Stroke Diesel
08-06-2012 07:47 PM
cowboybootlegger
02-20-2010 12:10 PM
