Any advice for building a driveway over mud?
I have some property that is high in the back, but the road frontage stays very muddy, the mud ranges from 8 - 18 inches deep It is muddy year round.
The driveway will not lead to a house, just to the higher ground in the back where I want to hunt, shoot, camp etc. Also, the driveway doesn't have to be car friendly, it just has to be accessible by 4x4 pickup and small tractor (Ford 850). It will be several hundred feet long.
I know that the best way to do this is to excavate all of the mud and fill with something else, but I am looking for something easier and cheaper. I don't want to excavate at all, I need some kind of rough floating road, so my truck and tractor wont immediately sink to the axles. Does anyone have any advice on the best way to proceed?
Received 3,102 Likes
on
Road base fabric with 3/4 minus over it worked well in a swampy area behind my house. The fabric is a bit heavier than garden fabric, but the same concept.
It may help to establish which way the water moves through the area, and add a french drain to give the water a bit more defined path.
http://en.wikipedia.org/wiki/Marsden_Matting
Available but you have to contact them for a quote:
PSP Landing Mat | Calumet Industries
I'm ok with easy, cheap and temporary. What would you suggest if longevity was not important, just cheap and easy access over several hundred feet of deep mud?
This is basically what I am most tempted to do, but before I start dumping load after load of rock, I thought I would ask around some. I'm afraid that this area would swallow up huge amounts of rock with little or no benefit.
on
If there are any sawmills in your area, you could try slabs. They are the first cut down the log to square it off. Flat on one side, rounded off on the other. Lay them flat side up perpendicular to your direction of travel and butt them up to each other. You could even brace them to each other with curb slabs and some lag bolts. It is an old road building technique that was fairly common in the old days for temporary roads. There is a road in this county called Old Plank Road, because it was initially constructed this way.
No idea how true it is, made me think of it when I read that.
Could of been a story to tell a young kid travelling in a semi at the time.
The amish do that still when they log an area out. Gotta watch your sidewalls though on those skid roads.
