PMF RSK 3 Months Later
#31
Not to detract from the current conversation going on right now, but I just wanted to throw in a little update.
I installed rear sway bar links (Mevotech) on the front, and it made a world of difference. I can't say if it solved all my problems, but the clunky sounds were definitely the sway bars hitting the springs. There's a good amount of separation now, plus the there's more distance between the track bar and sway bar. Overall, this was a good decision, and I think it should ALWAYS be a part of the RSK discussions and build threads.
#32
How much lift the SD springs contribute to the height depends on the spring code you use. My U codes are near flat and contribute no lift.
From F350 OBS springs that had a helper leaf added (my previous owner of the donor truck) I gained about 2.5" to 3" going to the 2.5" PMF RSK and U code springs.
#33
Brad is your truck a F250 or F350?
My drag link has way more angle than stock since the conversion and I think that's what's giving me bump steer. I don't see how the track bar could have anything to do with it as long as it's the right length.
My PMF kit was one of the first ones so I don't know if that could have anything to do with it?
My SD springs are pretty close to being flat.
#34
Well I'm using the same setup although my track bar is not adjustable. I lengthened the stock one using a sleeve. So I wonder why I have bump steer? I've thought about using a stabilizer but those seem to be not recommended.
#35
One truck was a F250(converted) one truck is a F350.
My 2 PFM kits were literally the FIRST and second ones he made(my truck was the one who got measured and I got 2 prototypes
#36
#37
Do your front springs have the spacer under the two leafs or does your SD springs sit right on the axle?
#38
#39
#40
I might need to post a pic of it but when I removed the stock springs there was a spacer about the thickness of one leaf under the two leafs if that makes sense. I was going to leave them off since the SD springs didn't have them but then the SD springs hit the traction bar mounts on the axle. You got a picture of your D60 setup?
I would love to be able to lower the front end a bit.
#41
#42
Edited to add: Mevotech said the overall length of the MK80016 is about 12.9".
