I have a buddy who just bought a 2013 f350 xlt. It came with the straight glass and he upgraded to the power sliding window. We both assumed that the wiring harness' would be there to hook up. But they werent. I wanted to see if anybody has done this and maybe we're looking in the wrong location. He would like to make it look factory, however I just don't know if it's possible
The plug appears to be in the right rear of the cab not under the floor but behind the trim along the C pillar.
I'm going to take a good look at that tonight thanks! And also would you happen to know if they also give you the harness to plug in the switch? I took the overhead console out and didn't see anything. But I figured it's probably inside the liner
Why would you need sliding rear window?Mine is leaking,I wish I didn't have it.
He loves it.. he had a chevy before with it and he always used it. But a buddy of mine had the same problem 3 years ago with his 07... he took the whole window off, re-sealed it, put a nice heavy coat on and not a problem since.
