has anyone done a maf conversion to a 5.8 351w??
Old 04-05-2015, 10:40 PM
1989f1504x4's Avatar
1989f1504x4
1989f1504x4 is offline
hi guys im new to fte but i was wondering has anybody out there done a conversion to mass air flow from speed density on a 5.8 351w? reason i ask is becuase i would like to put a decent size camshaft as im am doing a factory roller 351 engine build . and i got a great deal on a lunati roller camshaft .544 lift at .50 for $50 thanks for any help
Old 04-05-2015, 11:01 PM
Puddy's Avatar
Puddy
Puddy is offline
Old 04-06-2015, 06:23 AM
1989f1504x4
Thanks for the link but what would a guy do if he has a c6 transmission ?? Thanks
Old 04-06-2015, 06:58 AM
Puddy's Avatar
Puddy
Puddy is offline
It's easier than pie. No need to worry about the transmission.
Old 04-06-2015, 07:30 AM
1989f1504x4
Ok so what should I do a computer ?
Old 04-06-2015, 07:46 AM
Puddy's Avatar
Puddy
Puddy is offline
Mustang computer. Cal code A9L, 8LD.
Just read what I posted, it's the same, minus the Trans.
Old 04-06-2015, 08:06 AM
Puddy's Avatar
Puddy
Puddy is offline
Old 04-06-2015, 08:25 AM
1989f1504x4
Thanks so much, now hopefully I can use that camshaft
Old 04-06-2015, 08:58 AM
Conanski's Avatar
Conanski
Conanski is offline
Duration is more important than lift, what are the full cam specs?
Old 04-06-2015, 09:20 AM
1989f1504x4
I'm not for sure I think its a 268 duration . Its a lunati. Part number 51012
Old 04-06-2015, 10:09 AM
1989f1504x4
Intake .544 exhaust.560 duration is 242 . It says I need a 3000 stall. I dont want to use a stall converter. Can I get by without a stall converter?
Old 04-06-2015, 10:10 AM
Conanski's Avatar
Conanski
Conanski is offline
Yeah... that is a monster cam for an otherwise stock motor in a pickup truck, the motor would run but it won't make useable power.
Old 04-06-2015, 09:56 PM
cbakker's Avatar
cbakker
cbakker is offline
That cam is way too big. Unless you have aftermarket heads and bumped up compression, you are wasting time putting that cam in. Doing a MAF swap will make it run ok, but it will have a rough idle no matter how you tune it.
Every converter has a stall speed. 3000 stall converters are for racing applications. This won't be a good match for anything but a drag truck. If you could get the power that cam is designed for, you would shell out a stock C-6 converter pretty quick.
Tashortie
08-19-2018 02:23 PM
Tashortie
08-19-2018 10:16 AM
95f2504x4
03-07-2011 03:52 PM
jklapp86
04-01-2008 07:37 PM
97F250
11-18-2002 01:44 PM
Quick Reply: has anyone done a maf conversion to a 5.8 351w??
