1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
4r100 swap... grinding noise
Old 04-05-2015, 07:40 PM
blacksmoke7.3's Avatar
blacksmoke7.3
blacksmoke7.3 is offline
Hi I am new here hoping to get some help here. I have a 2002 ford f250 it has a 5.4 with a 4r100. The original transmission only had foward. So I got a used low mileage transmission from a local junkyard in a truck I drove the truck down the road to make sure all was good. I removed my old transmission and put the newer one in. Hooked it all up filled with atf. I started the truck and it has a grinding noise coming from starter area. The starter is not hanging up. But appears to that the gear is rubbing the flywheel I can see where it rubs and such. I went on to shim it out I put a flat washer on each bolt between the starter and bellhousing. The noise seemed to get worse! I need help. I just bought the truck it's going to be a plow truck so I can park my 03 arizona 7.3 for the winters. Please help!
CSL
1997 - 2003 F150
05-04-2014 09:00 AM
lemasters f100
04-12-2014 02:37 PM
benpierce2233
12-16-2012 11:20 PM
tsheriff
01-26-2006 10:51 PM
bpete
03-08-2004 03:47 PM
Quick Reply: 4r100 swap... grinding noise
