02 Stolen Friday Night
#33
I hate that your bad luck has caused me (and presumably others) to act....but I just put a Club on my steering wheel today, and have a Cyclops coming in the mail tomorrow.
As much as I'd hate for my truck to be stolen at home, I'd hate it worse if I was at a hotel with trailer in tow and show-car strapped inside!!
#34
Ok, go get that done tonight!
Same here. I have a Club in my cart on Amazon and I have a Cyclops in my to-do list. These trucks are SO easy to steal that it's almost worth a recall.
That 150 bucks for a Cyclops beats the heck out of a 500.00 lojack.
#35
Are they easy to start without a key?
#36
Can you help enlighten me on what makes them easy to steal? I know the doors are friggin cake to get into after I locked my keys inside with the rig running (long story) and watched the AAA guy open it up....I started to wonder why I even lock it.....
Nope for obvious reasons , but 2006 - present things are better. You need the key ID after that AFAIK. (as far as I know)
#37
Dang that sucks. Here's to hoping for a good turn out. There's a local guy who's had his truck stolen 3 or 4 times now. Gotten it back every time so far. He's got a Ravelco in it now.
The new ones are still getting stolen. Apparently the little chip in the key isn't as foolproof as marketing would want you to believe.
#38
Sent from my Telegraph using IB AutoGroup
#39
Thanks for the correction! I knew it was close to there.
That's for sure. But it usually keeps the local yokel from just jumping in and joyriding it. Pre 2006 you just need to budget in some anti-theft.
Club for visual deterrence, $40.00
Cyclops (or other) for second level prevention $150.00
Would be nice if Ford just came up with a real plan and followed it.
#41
A real simple way of disabling the truck is to use a couple of the customer-use wires to interrupt the coil to the IDM's power relay. A hidden switch will interrupt power to the IDM. When they break your ignition key switch and crank it over, the instrument panel will appear absolutely normal, but the engine won't fire, just crank and crank.
The beauty is that the experienced thieves will immediately know if you've added any other kind of cut-off switch, and may go looking for it, but a "no IDM" condition has virtually no visible symptoms. It just won't start.
By that time, you can be out there with a blunderbuss.
Years ago, I put something together like this, and others have also built it. I have an email from one of them that told me it saved his truck one night.
If anyone's interested, the system is described here:
SpringerPop's Disabler.
BTW, that Cyclops relay is best used as the IDM power relay. It's a slick system. The only down-sides are it requires you to carry a second clicker around, and it will shut down your truck if the clicker is pressed while driving.
Pop
Pop
#42
#43
Then again, it is hard to try and prevent something when you don't exactly know what that something is......I'll look into SpringerPop's solution.
#44
My boss rigged his fuel cutoff solenoid to a push button hidden under the dash on his 96 12 valve. It won't open without hitting the button. Not sure how you'd rig it on a 7.3 but it's a cheap, simple solution
#45
When I had to smog my truck last time I removed the switch from my DP tuner chip and hid the cable and it would not start. Had to plug it back in and hide it under the dash for the smog check. An experienced thief may know what to look for though.
