Any idea what this is??
This is my first Super Duty (2010 w/ 6.4)... the dealer I bought the truck used from had no idea either. The top clear part blinks red and on the bottom there is a button. This is located on the bottom left of the dash under the steering wheel.
Also curious what the thing next to it is which looks like I can plug something into it.
On the first piece, see if you can trace where the wires are going to... that might help.
Not sure on the first piece but the second thing is your OBD II port - the dealer uses it for programming the truck, places like Autozone can check any errors that you get (you can even do it yourself with a scanner). a tuner for the truck would also connect there.
On the other device, I traced the wires and they appear to go into a harness and out through the firewall, but I lose them before that happens. I am not looking at it now, but I believe their were four wires coming out of it. It blinks 24/7 regardless if the truck is off or I am driving. It is in a spot where it isn't bothersome, but I am just curious what it is!
I know it was used to haul livestock gooseneck and other ranch stuff. Was owned by a lady.
It is a mint condition 2010 KR CCSB with only 58k, so don't think anything too crazy.
when does it blink?? like is the truck running at the time or everything off?? if its off then its most likely an alarm. some of the alarm systems when they came with "replacement" remotes to use in place of the factory ones they would have those buttons to retrain new remotes to them... friends truck we had to hold it for 5 seconds to enter the program mode.. then the horn beeped to tell you it was in... you pressed the remote buttons and the truck would beep again to say it was programed.. you wouldnt press anything for a about 10 seconds it would beep once more to say it was exiting programing mode...
hmmm unsure then... the alarms only blink when the vehicles are off... hopefully youll be able to follow it through the firewall sometime if it leads through it...
