TILT RELEASE ON '90 F53
I have a 1990 class A motorhome, 460, AT, F53 chassis. Where is the release lever for the steering wheel tilt? I think it might be causing a 'no crank' problem with my ign switch. The only things I can see on the column are the turn signal lever, the hazard switch & the key release.
Received 3,102 Likes
on
That's gotta be it. Thanks. It's jammed and will not release. Also the metal rod to the ignition switch seems to be jammed against the lower dash. I'm off to Harbor Freight for a wheel puller.
Davie, did you match up the alignment pin holes on the key cylinder & the ign switch?
kyle1979ford
11-04-2013 09:01 AM
whitezombie198
04-06-2009 05:07 AM
Jarrett T
02-19-2004 11:13 PM
