Rear Differential Noise and Smoke
Went for a 12 mile drive at an average speed of 45mph, limited stop and go. Ambient temperature is 35 degrees. Here are the temperatures
Drivers Hub 62
Passenger Hub 63
Rear Center Diff 96
Rear Driver Side Diff 126
Rear Passenger Diff 95
Rear tube out to drivers wheel - ranged from 70 to 50 then increased to 80 as I reached the rotor
Rear tube out to passenger wheel - ranged from 60 to 40 then increased to 80 as I reached the rotor
Front of differential near pinion - 89
Both rear calipers - 72-75
The one in bold seems to be the odd ball out.
Drivers Hub 62
Passenger Hub 63
Rear Center Diff 96
Looks like you found the problem!
Just remember, all of the filings/pieces from that thrust washer or carrier shim that you found are still in there and going through all of the bearings, hub bearings, pinion bearings, carrier bearings, the more you drive it the more damage you are going to do to everything in there!
If I remember correctly you did something with that diff a few years ago!
I think you are going in there again.
You had it stripped down already, four bolts and you would of had the carrier out and could of had a look at the bearings! Haha. I would say the side bearings are shot by your temp readings. Time for a rebuild. It's been a while since I rebuilt a sterling but I don't remember them being difficult . Good luck.
Drivers Hub 62
Passenger Hub 63
Rear Center Diff 96
Drivers Hub 62
Passenger Hub 63
Rear Center Diff 96
Sorry to get off topic, but does anyone else see the optical illusion in this pic. It's the first thing I noticed. The best kind are the ones not rigged.
Well I think it's highly unlikely a trust washer/shim went bad. They are between the race and the housing on that carrier. But that doesn't mean the bearing isn't bad.
If you pull the axle shafts, than the 4 bolts on the bearing caps. Be careful, as if the bearings are shot, that carrier is basically going to want to fall right out after the last cap is pulled off. Usually they should be nice and snug. A set of pry bars, and it should slide out without too much issue. Make sure you keep the bearing caps, shims and races separate for what side they came off of.
Yes those are old and the gears were replaced after whatever caused those....well that was the conclusion we came too - this is a used axle that I put in this truck - so don't have a real history on it. Starting to wonder if it was "fixed" properly the first time.
#29
#30
