Ford 9 inch Axles
04-03-2015, 12:47 PM
Ford 9 inch Axles
Greetings all.
I have searched the forums but cannot find an answer to this question:
Do all Ford 9 inch differentials have two different axle lengths??
I have a 1970 F-1 differential and axle housing in my F-1 but if I remember correctly both axles were the same length.
Thanks
04-03-2015, 12:52 PM
I think some Econolines had equal axles, not sure why.
04-03-2015, 01:22 PM
All the '57-'72 F-100 axles had equal length shafts.
04-03-2015, 01:25 PM
Ach, you're right, I was thinking "centered pinion", which actually requires unequal shafts.
04-03-2015, 05:05 PM
on
Not too related, but also don,t see much in search...
Are you using the emergency brake cables original to the truck with the 9 inch?
04-03-2015, 07:08 PM
Quote:
Originally Posted by
kjn49
F-1 e brake cables work with a 9 inch rear.
04-04-2015, 11:53 AM
9 inch axles
All, Thanks for your help. I was getting worried that I perhaps had an issue.
I used the original rear brake cables with the 1970 F-1 housing in my F-1 and they worked fine.
04-05-2015, 09:38 AM
B7TZ-4234-A .. 28 Spline 9" Axleshaft - R/L same / 1957/67 F100.
C8TZ -4234-A .. 28 Spline 9" Axleshaft - R/L same / 1968/72 F100.
C8TZ-4234-B .. 31 Spline 9" Axleshaft - R/L same / 1968/72 F100.
9" Passenger Cars, Bronco's & Econolines have specific right & left axle shafts.
bob_351
03-04-2011 05:59 PM
FatMike86
06-11-2007 06:43 PM
51panhead0
02-20-2007 04:12 PM
