I run a 2001 F150 4X4 5.4 V-8 7700...seems that my day-time running lights have stopped working...high beams and all other lights work. The emergency brake is off. Is the a resistor or something that I need to replace that has burnt out.. Thanks.
Not sure if the wiring is the same but, my '01 F150 had the fuse blow that protected the running lights and overdrive shutoff light and switch on the shifter. Bare wire on the shifter OD wire was the cause. Under cover at top of column.
I just checked all my fuses and all are good. I did replace my power steering hoses awhile back, is there anything that I could pulled lose by mistake that would of effected my running lights. I did look underneath to check but didn't see any loose or hanging wires. Thanks
