low oil pressure....5.0
my 88 f150 has a 5.0l with 5 spd tranny. oil pressure is at 5 psi on idle (i have mechanical gauge) on cold start up it is at 40-45psi but once it warms up and idles its down to 5-7. when driving and my rpms are at around 1800 my oil pressure is only like at 12-15psi. any ideas? oil change brings it up a few psi but thats it
i was thinking that as well. the engine has around 130k on it. it doesnt knock or anything. no weird sounds on start up. im thinking about takin it in and putting a new oil pump screen, oil pump, oil pan gasket (has a small leak on the pan) and new main bearings. just trying to bring some life into her. she runs great though, no lack of power or anything. so im thinking compression is good especially with low oil pressure
i will have to find another. can i just switch the gauge itself and leave the copper line in? i dont wanna get underneath again and try changing the copper line
You may have heard about the " idiot gauge" that the Ford oil pressure gauge became. Quite simply, Ford got sick of all the criticism about low oil pressure at idle and the resulting expensive warranty claims. They rigged the gauge to read mid scale and used an idiot light sender that did not kick off until pressure was very low.
There is a lot of video out there showing engines running without oil and the truth is they will run at idle for a very long time without damage. The fact that oil is still flowing, even at low pressure will protect your engine and I would prefer the increased flow and reduced frictional losses of loose clearances over high idle oil pressure anytime.
Bottom line, it's by design. Don't worry about it.
There you have it. It ain't broke!
what if my rpms are like 2k and pressure is at like 12-15psi? im starting to think getting that aftermarket gauge was a bad idea lol. im starting to worry. i love my truck and dont wanna see her go. put too much wrench time into her
I'd personally just stick with a conventional 10w-30 OR 10w-40 oil. 5w-30 for winter use only. Stay away from synthetic blend and straight synthetic as this will also drop your psi by a few numbers. They are smaller molecules and therefore slide by even more when tolerances are not as tight 100,000 miles or 50,000 miles ago. Just saying..
Be sure that you use a Motorcraft or Wix, even Napa filter. Stay as far away from Fram if at all possible!!!
12-15 psi should be ok. I'd let sleeping dogs lay and just do regular maintenance as needed. If it really bothers you, open your wallet up and spend around $1500 for a complete rebuild and see comfort with 25-30 psi @ idle.
JohhnyVW21
1983 - 2012 Ranger & B-Series
08-02-2018 10:45 PM
insane96
02-15-2013 10:07 PM
ghettomonkey2003
13
05-24-2004 01:38 PM
