ats turbo low boost..
04-01-2015, 03:52 PM
on
After my new engine install my ATS turbo has low boost anywhere from 10 to 15psi max! I've got a r&d 90cc with the WG wired shut. My pipes are sealed with no leaks. I just replaced the snail gasket thinking that was it, it wasn't.. sounds like a boost leak around 15psi but I've got none at the moment, with the old engine I could hit 20psi real easy.. something I'm missing? Any help would be great thanks guys
04-01-2015, 07:08 PM
04-01-2015, 07:28 PM
on
Nope, just studs on a new engine.. intercooler in a few months
04-01-2015, 07:51 PM
well it's not a ic boot issue then.what about the boost gauge tube?
hey,i drove through your home town recently.Yosemite park to livermore.
04-01-2015, 09:07 PM
on
Quote:
Originally Posted by
FORDF250HDXLT
Awesome!! Its a new hose lol with fittings.. scratching my head on this one, the only thing changed is a new engine
04-01-2015, 10:10 PM
on
d-day
injector pump timing more advanced on new engine than previously? won't light the turbo like retarded timing
04-01-2015, 10:39 PM
dropitlow88
This Fel, Do you need me to send you my meter? Im going to time my Bronco as soon as I get it fired up, but after that, its free to go wherever...
2* could be worth 3psi.... What does your intake tube look like? 3" DP?
04-02-2015, 12:11 AM
on
RacinNdrummin
I'm at 6.5* intake is clean and clear with a new k&n.. should I go more advance?
04-02-2015, 12:17 AM
on
DP is the biggest you could slide into the turbo
04-02-2015, 08:44 AM
Advancing it from there wont help boost, only top end.
What are your EGT's looking like?
04-02-2015, 10:34 AM
on
Cruising temp is around 500-600F* at 60mph 2300rpm.. stick your foot into it climbs fast. I can post a video in a few if that helps
04-02-2015, 10:38 AM
did you reman the engine,buy used,or?
04-02-2015, 11:10 AM
Are the bearings in the turbo good? If its side loading it wont like building higher boost. But sounds like it was working good on the others.
04-02-2015, 11:23 AM
on
FORDF250HDXLT
Reman by promar precision engines in NJ.. that's all they do is diesels
hairyboxnoogle
Yes turbo is good, the old engine was pushing 20 plus psi
04-02-2015, 11:41 AM
I wonder if the seal on the up-pipe is leaking from removal?
Gotta be a boost or drive pressure leak somewhere...
