Rough Idle - New Guy Here!
Old 04-05-2015, 09:38 PM
95_Dually's Avatar
95_Dually
95_Dually is offline
My LUK cost me about 1000.00 in 2010 as I recall.
  #62
Old 04-05-2015, 09:40 PM
96F250SD's Avatar
96F250SD
96F250SD is offline
OH MY GOD!!!
  #63
Old 04-05-2015, 09:41 PM
95_Dually's Avatar
95_Dually
I don't believe it can be inspected until it is removed. I had no idea my problem was the flywheel/clutch until it exploded on me in New Mexico and took out my starter too. I was headed to South Carolina from California so as you can imagine, I was pretty bummed.
  #64
Old 04-05-2015, 09:42 PM
95_Dually's Avatar
95_Dually
The dual mass flywheel will cost you the same as the single mass conversion but the next clutch will be a lot less expensive. I had 199,000 miles on my original clutch.
  #65
Old 04-05-2015, 09:44 PM
96F250SD's Avatar
96F250SD
96F250SD is offline
Which would be the better way to go in the long run? dual mass flywheel or luk clutch?
  #66
Old 04-05-2015, 09:45 PM
95_Dually's Avatar
95_Dually
Riffraff Diesel has South Bend Clutches. They are a bit cheaper. Here is the link. Talk to Clay, he's a great guy.
Ford - 94-97 'OBS' 7.3L - Drivetrain - South Bend Clutch - Riffraff Diesel Performance
  #67
Old 04-05-2015, 09:46 PM
95_Dually's Avatar
95_Dually
The single mass is the best way to go. Whether it is a LUK, Valair or South Bend.
  #68
Old 04-05-2015, 09:47 PM
95_Dually's Avatar
95_Dually
The clutch pedal is so much lighter when it's upgraded to the single mass too.
  #69
Old 04-06-2015, 07:58 AM
madpogue's Avatar
madpogue
madpogue is offline
To check the flywheel, remove the inspection cover. Try to move the flywheel. If you can move it several degress, it's on its way out.
  #70
Old 04-06-2015, 08:36 AM
96F250SD's Avatar
96F250SD
96F250SD is offline
I will definitely check tonight. Can't wait to get it fixed!!
Edit: Is it safe to drive like this or will it possibly cause damage to the crank or transmission? If it will just go and leave me somewhere that's fine I'll tow it myself home but if it can cause damage to the big 2 I'll replace it before I drive it.
  #71
Old 04-06-2015, 09:11 AM
farmert's Avatar
farmert
farmert is offline
On the DMF, if you can rotate the flywheel 5/8 of an inch fairly easily it needs to be replaced. It sounds like the center bearing is going bad, as what happened to my 97. That cost me a tranny, as it cracked the bell housing. I would replace it asap.
  #72
Old 04-06-2015, 11:02 AM
96F250SD's Avatar
96F250SD
96F250SD is offline
Good to know! I will go he tonight and pull the cover weather permitting. If it is bad I'll pull the transmission n t-case to replace it all. This is my first hydraulic clutch setup so how does all that work in way of maintence? Bleed it or not even touch it?
Also the south Bend stock power looks like A good option to the link above, assuming it's a single mass... will call him later to find out!
  #73
Old 04-06-2015, 01:59 PM
farmert's Avatar
farmert
farmert is offline
The clutch slave cylinder is held on to the bell of the tranny with a spring clip. Just pry it off of the bell without removing the hydrolic line. The ram of the cylinder will expand out, but it will compress to get it back in place on the bell on reassembly. If you remove the hydrolic line from the slave, it can be a beach to get all the air out of the system.
  #74
Old 04-06-2015, 02:04 PM
96F250SD's Avatar
96F250SD
96F250SD is offline
Good deal I won't mess with the line then, but does that flywheel and clutch sound right? I can get part numbers in a sec.
  #75
Old 04-06-2015, 02:20 PM
farmert's Avatar
farmert
farmert is offline
If you are talking about the one from Clay at Riffraff, that looks right.
Quick Reply: Rough Idle - New Guy Here!
