Loud creaking when turning? Transmission crossmember?!
Old 03-11-2002, 12:22 PM
theleetbeagle's Avatar
theleetbeagle
theleetbeagle is offline
Hey, guys. I just read a post here where:
"3) I have the creaking transmission crossmember which you'll also see on this site"
was mentioned. I couldn't find the originating post, but I need to know something...
My 96 F-150 I6 Mazda 5-sp always (almost always) has a loud creak whenever I turn left or right. The turns don't need to be sharp at all...the creak is almost always there. I thought at first it was my toolbox in the back, but I removed it and it's still there.
I have been hypothesizing this since I bought the truck: loose rear shock sliding around, bed liner sliding around, etc etc etc.....but this "transmission crossmember" is really getting to me...
Has anyone else experienced this loud, annoying creaking when turning? Sound seems to be coming from the rear...
Hey, thanks!
-Nick.
Old 03-11-2002, 04:25 PM
mjb1962's Avatar
mjb1962
mjb1962 is offline
The creeking could also be coming from loose front crossmember to frame mounting rivets. I found one on my F150 under the spring/shock mounting bracket near the steering box. It caused an annoying creek when steering at slow speeds. They can be replaced with grade 8 bolts and nuts. Have someone turn the wheel while you observe. Listen for noise and look for movement. Be sure and block the wheels!
Mark
Old 03-11-2002, 07:02 PM
beratte's Avatar
beratte
beratte is offline
There's a TSB on the frame creaking. If you're still having problems with it let me know and I'll send it to you.
Old 03-11-2002, 11:38 PM
groundrat's Avatar
groundrat
groundrat is offline
Nick, I have a 94 F150 that used to have the same creak. Drove me up the wall. I eliminated the noise by removing all of the crossmember bolts, and replacing them with new grade 8 ones coated with a little lock tite. Real easy fix. Hope it works for you.
Bill
Old 03-12-2002, 06:09 AM
mic's Avatar
mic
mic is offline
Hey beratte I sure could use a copy of that tsb, if
you could plz send it to me, I sure would appreciate it.
My e-mail address is jmcp@ite.net..... thanks
Old 03-12-2002, 12:32 PM
wesmansr's Avatar
wesmansr
wesmansr is offline
Please post the TSB for all our benifit.
Thanks
Old 03-12-2002, 12:43 PM
beratte's Avatar
beratte
beratte is offline
I'd like to but it's pretty long, 20 pages. I'm working on a web site and will post it there when I'm done. I can email it out though.
Old 03-12-2002, 12:47 PM
wesmansr's Avatar
wesmansr
wesmansr is offline
Please email it to wesmansr(No Email Addresses In Posts!)
Thanks
Old 03-13-2002, 05:55 PM
Green_Monster's Avatar
Green_Monster
Green_Monster is offline
hey guys I seem to be having a similar problem the noise sounds like its coming from the firewall or just in front of it. I have a 93 f150 4x2 with 300 and a mazda 5spd. The noise is driving me to drink
Old 03-14-2002, 07:28 AM
drm7's Avatar
drm7
drm7 is offline
*&$#,I think I have a similiar problem. Under slow speeds and turns I get a creeking/popping. What exactly do I have to replace to stop this? I have had cars make noise before but if everyone else has this problem then I'm sure I do to. Which bolts do I replace?
Please email me the TSB @ guest00@attglobal.net
Thanks!
1994 Black/Silver F150 XLT 4x4 Reg Cab / Short Bed, 3.55 LSD, 5.8L w/84k miles, K&N drop-in
Upgrade wish list: 31x10.5, Gibson exhaust, MSD ignition, helper springs, lights
Old 03-14-2002, 07:49 AM
theleetbeagle
I wish I knew exactly. I emailed one guy that had this problem and PM'd another (both in this post) and neither have gotten back to me in over three days.
This weekend, if the warmth and sunniness do not subside, I will get under the truck and take a peek.
From what I've gathered is that there are huge rivets that must be drilled out and replaced with large nuts and bolts. Problems have been found on the tranmission mount crossmember and on frame crossmembers...dunno EXACTLY where, though
NJK
Old 03-14-2002, 10:06 AM
beratte's Avatar
beratte
beratte is offline
Here's another thread on the same topic, people seem to have the best results with retorqing the tranny crossmember bolts.
Old 03-14-2002, 10:09 AM
beratte's Avatar
beratte
beratte is offline
Oops, here it is: http://209.185.240.250/cgi-bin/linkrd?_lang=EN&lah=3cf538feb1950eea39987cb60b6551 11&lat=1016121595&hm___action=http%3a%2f%2fwww%2ef ord%2dtrucks%2ecom%2fdcforum%2fDCForumID39%2f3533% 2ehtml
Old 03-14-2002, 10:16 AM
beratte's Avatar
beratte
beratte is offline
The previous is a bad link, sorry. This is good:
https://www.ford-trucks.com/dcforum/DCForumID39/1755.html
Old 03-14-2002, 11:28 AM
FNhugeK's Avatar
FNhugeK
FNhugeK is offline
I wouldn't mind a copy of the TSB as well... I have a similar problem with my 1996 F150 I6.
kris_park(No Email Addresses In Posts!)
Thanks!
Quick Reply: Loud creaking when turning? Transmission crossmember?!
