First oil change? - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign In
Register Forgot Password?
6.2L V8 Discuss the 6.2L V8
First oil change?
Old 03-31-2015, 07:55 PM
Duwop's Avatar
Duwop Duwop is offline
Duwop is starting off with a positive reputation.
First oil change?
I'm looking for suggestions as to when you would do your first oil change. I've got 800 miles on my new 15 Super Duty 6.2 and am thinking that it might be a good idea to change the oil in the 2-3k mile range. Let me hear it good bad and ugly.
Old 03-31-2015, 08:42 PM
ATP Pilot's Avatar
ATP Pilot ATP Pilot is offline
ATP Pilot is starting off with a positive reputation.
nothing bad about it.
I did my first change at 1,500 miles, then at 5000 miles and every 5000 miles there after.
I always know when it is due with out having to write it down...because its on the 5's...10,000, 15,000, 20,000 etc.
__________________
2013 F250 XLT 6.2 CC 3.73 2wd
-ScanGauge, Rear Timbrens, Curt Q16 hitch, Line-X
-2015 Wildcat 317RL
-AKA "Learjet"
Louisiana
Old 03-31-2015, 09:40 PM
rvpuller's Avatar
rvpuller rvpuller is offline
rvpuller has a great reputation on FTE.rvpuller has a great reputation on FTE.rvpuller has a great reputation on FTE.rvpuller has a great reputation on FTE.rvpuller has a great reputation on FTE.
First change was at 3K and now every 5K or when we are close to a Ford Fast Lane when its close the 5K mark.
Denny
__________________
Moderator 6.2 & V10 Forum
2013 F350 Lariat SC DRW 2WD 6.2 4.30 Gears Air Lifts 50 Aux tank
2003 HH Premier 35 FKTG
Retired 2000 F350 Lariat SC DRW V10 4.30 Gears BrakeSmart
Air Lifts 4X2
http://www.ford-trucks.com/guidelines.html
Old 03-31-2015, 10:01 PM
Fireboater's Avatar
Fireboater Fireboater is offline
Fireboater is starting off with a positive reputation.
Oil Change
Hi there, since my truck has synthetic, is every body sticking to synthetic for the life of the Truck.
Thanks John
Old 03-31-2015, 10:22 PM
rvpuller's Avatar
Quote:
Thanks John
I'm using the Ford blend but that's also what the dealer uses when they change it.
Denny
__________________
Air Lifts 4X2
Old 03-31-2015, 11:17 PM
DCP's Avatar
DCP DCP is offline
DCP is starting off with a positive reputation.
I did my first oil change at a 1,000 miles, even though the dealership said that it wasn't necessary. I change my oil every 3,000 miles, but If you change your oil every 3,000 to 5,000 miles, you should be good. I don't believe in extended life oils or using the trucks oil reminder for my oil changes. Also, I don't trust anyone to work on my vehicles, so I do all my own maintenance and repairs myself.
Old 04-01-2015, 07:19 AM
Duwop's Avatar
Thanks for all of your comments. I also have a 96 F150 4.9 that has had the oil changed every 3-5k and now has 202,000 on the ticker and have not had any issues. I think that while use during break in period when all internal parts are seating there is a chance for filings during this period which is why I think that a oil change is a good idea. The 96 never had an early oil change and it hasn't been an issue, that said I hope to get the same reliable service out of the new 6.2 for the next 20 years as I've gotten from the 96
Old 04-01-2015, 10:53 AM
DCP's Avatar
DCP DCP is offline
I hope to get the same reliable service out of the new 6.2 for the next 20 years as I've gotten from the 96[/QUOTE]
This is why I bought a gasser over the diesel. A lot of the Power Stroke fanboys on FTE don't understand this, or they never intend on keeping their truck after it's paid for.
Old 04-01-2015, 12:38 PM
Long Haul's Avatar
Long Haul Long Haul is offline
Long Haul has a very good reputation on FTE.Long Haul has a very good reputation on FTE.Long Haul has a very good reputation on FTE.
Quote:
New motor I go 1k then Amsoil goes in...
On this truck I just picked up Monday I will make the switch at next recommended interval....According to the window sticker the dealer must have just changed it before the truck hit the used lot.
__________________
Mike...
~2011 F250 Lariat CCSB 6.2L 4x4 4.30/Carli Back Country 2.0/Llumar 20% Tint/Back Rack/Yaesu FT-7900R/Autometer Gauges/Interior LED's/Fuel Maverick Wheels/Toyo Open Country AT's/Mobil 1/
Old 04-06-2015, 02:45 PM
JM96F250 JM96F250 is offline
JM96F250 is gaining momentum as a positive member of FTE.
Just did mine at 4000 miles. Used what the manual said to use. It even has the part number for the filter. Rotella synthetic blend. Wal-mart carries it.
Old 04-06-2015, 10:48 PM
DCP's Avatar
DCP DCP is offline
Quote:
I don't recommend using any diesel motor oil in a gasoline engine, especially in a modern gasoline engine. And, always use a high quality oil filter.
Old 04-07-2015, 06:20 AM
Quote:
Damnit. I said Rotella. I used Motorcraft. The one in the red jugs. I get the two switched because I originally ordered a diesel.
Yea, I used motorcraft. And a motorcraft filter that the part number was listed in the owner's manual.
Old 04-07-2015, 09:33 PM
B327Thr B327Thr is offline
B327Thr is starting off with a positive reputation.
I was going to say, Walmart sells the "Motorcraft Filter". That is high quality from what I've been told. At least for my 6.0 it was.
__________________
'03 F250 6.0L 4X4
'15 F350 6.2L FX4
More to come....
Old 04-08-2015, 06:15 AM
Quote:
Yea, the owner's manual even has the part numbers.
I have no idea why I said Rotella. It was Motorcraft Synthetic Blend I used.
Old 04-08-2015, 08:52 AM
ATP Pilot's Avatar
good deal, I was worried when you said Rotella.
FYI...I researched both the Motorcraft filter and Semi Syn oil...Bob's the oil guy...etc...both came back with very high marks.
__________________
-2015 Wildcat 317RL
-AKA "Learjet"
Louisiana
Similar Threads
change oil after egr/oil cooler failure? JaySVX 6.0L Power Stroke Diesel 18 07-14-2013 02:52 PM
first oil change how many miles did you have ??? 11superduty 6.7L Power Stroke Diesel 45 06-12-2012 10:44 AM
1st oil change jmiley 6.2L V8 8 12-30-2011 07:00 PM
Oil Change Interval ruschejj 6.7L Power Stroke Diesel 7 11-06-2010 10:32 AM
Which oil is best for a 390? 48 F-2 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 30 10-17-2005 12:43 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
