2005 6.0 transmission filter change question (white gunk in bottom of canister??)
Just got it a couple weeks ago from auction. 2005 CCSB Lariat FX4 automatic. I have been running through the truck and replacing every filter and anything that needs replacing. Most filters on the truck were wix, everything now is back to OEM.
The truck had the infamous check TFT and flashing overdrive on the dash and wouldn't shift over 3rd gear. I changed the transmission fluid a couple weeks back when I went to sort out a TFT flashing overdrive problem. The fluid that came out of the truck was new fluid and so was the TFT sensor so my assumption is someone had tried to fix the transmission problem by changing the TFT sensor but in reality one of the harness connector pins was bent all the way over (the pin that went to the TFT of all pins). Easy fix but I still replaced the TFT and the complete harness since I was that far in the transmission before I found the broken pin. $280 for new harness, trans fluid, and TFT sensor. But I stole the truck from auction because everyone thought it had major transmission problems. easy enough fix in the drive way.
Today I went to replace the transmission filter after receiving it from dieselfiltersonline and finding my 22mm socket. The filter change was easy and strait forward. The filter itself looked pretty bad and there was about 2-3 oz of this white gunk in the bottom of the metal canister. Any clue what it is? Is it going to be a problem? Any advise would be great.
Thanks
D5
Thanks
D5
I just changed mine y/day, along with 8 qts and it was totally clean and a consistent color. Maybe because the filter is vertical, it works as a separator and I'm not just sure that there might have been water or contaminates that accumulated, turning the ATF mixture whiteish?
Also, Anyone realize how flimsy the filter assembly bracket is that holds that unit in place is?
I was concerned about creating a possible line connection leak when it flexed way too easy when trying to take it apart.
I got a bar clamp and attatached it onto the filter bracket to keep the assembly from flexing too much, before it broke free.
Something that could have created a real mess. Just surprised how Ford supported it?
DieselVol
01-22-2022 06:06 PM
Nitramjr
General Automotive Discussion
03-03-2010 05:31 PM
rooboy
06-26-2008 03:44 PM
