What is that recurring knock / tap sound???
I was about ready to respond to your first post but then read on to see that your issue has morphed. My response will still be the same however...pilot bushing. When a pilot bushing wears it allows the input shaft of the trans to engage in an "off-center" axis. How far off center changes with each depression/release of the clutch which explains how the noise changes or even goes away. The next step is the galling of the bushing which results in a "loud raspy sound". I used to run a lot of stick shift dune buggies out in the desert, the sand really wreaks havoc on pilot bushings so I have had more than my share of troubles in this area. Good luck!
Alta
11-24-2008 09:21 PM
ottawaguy
04-09-2008 08:39 PM
ford4life69
11-06-2007 07:51 AM
MrDeath8666
11-30-2003 07:53 PM
