71' 460 vs. 74' 460 timing gears
Old 03-30-2015, 09:43 PM
BBpwer's Avatar
BBpwer
BBpwer is offline
I have a 74' 460 and I am currently rebuilding it. I'm trying to figure out what Edelbrock heads i want. I ordered a comp cams cam and lifter kit then realized I would need the timing set, rocker arms, push rods, ect. I want this comp cams timing gear and chain set but it says it's for 68'-71' 460 motors and I was wondering if it would fit my 74' 460. Thanks in advance.
Old 03-30-2015, 09:46 PM
bkaul's Avatar
bkaul
bkaul is offline
I think '72 is when Ford retarded the cam timing to reduce NOx emissions? The '68-71 set would then be the non-retarded, higher-performance version, I think. I believe they're interchangeable, just have the timing mark moved by a tooth or two.
Old 03-30-2015, 10:06 PM
BBpwer's Avatar
BBpwer
BBpwer is offline
Ok thanks for the input
kevinfelix
10-10-2012 02:19 PM
gthbryce
07-07-2009 09:48 AM
fdude64
08-18-2008 08:30 PM
Bubba Blue
09-13-2005 01:09 PM
dcdave
02-22-2004 08:38 PM
Quick Reply: 71' 460 vs. 74' 460 timing gears
