Antifreeze leak
Antifreeze leak
I need a little help with a mystery leak. I have about 1,000 miles on a rebuilt engine. It had a small oil leak (about 2 drops every time I drive it) coming from the base of the oil filter adapter. I finally got the right angle to tighten the bolts and the oil leak seems to have gone away. Now I see some antifreeze collecting in the same spot. There is a little puddle of antifreeze on a flat surface next to the fuel pump and behind the oil filter adapter. I've attached pictures to show where I'm talking about. I also notice a stain running down the block on the front passenger side. It's a 360 rebuild (basically stock). I'm NOT a mechanic just a hobbyist. I'm trying to learn so thank you in advance for your help.
In this picture it looks oily, but it actually green in color.
You can barely see the lighted area behind the power steering pump and oil filter adapter. That is where the green puddle is sitting.
This is a shot of the flat area behind the oil filter adapter. There is a little pool of green antifreeze collected there.
Here's the fluid stain on the other side of the block.
Anti-freeze leaks can be sneaky. The areas it collects may not be where its leaking. I'd look above the areas of your pictures for leaks or white "leak trails". Cylinder head joint and water neck/T stat hosing are good candidates.
Maybe drive it for a while to get it warm, hose it off carefully and watch for leak location while idling. Water from the hose will evaporate fast on a warm engine... anti freeze more slowly and it leaves a white trail.
Clean/wipe off the coolant and any mineral trails and monitor/inspect. Yes, fire up the engine and allow it to build temperature and thus, pressure.
On an FE, that area next to the fuel pump and oil filter housing would lead me to conclude that something above it is leaking coolant. You know, with gravity in effect and all. Likely the left mount of the water pump.. I recall the bolts are through-holes.
In fact, with the right side leaking that would also lead me to replace the water pump gaskets as a matter of good maintenance and upkeep. Yes, replace both gaskets - not just one.
Wipe everything that is wet w/antifreeze dry. A long screwdriver (stick,rod,anything) with a paper towel taped to the end will get into those itsy places. Then start it up,run until warm,as previously stated, turn it off and very carefully look/FEEL for a small leak. By poking/feeling with your fingers and constantly checking your fingers for moisture you will eventually find the leak. And yes,like hio said ,the leak is assuredly up higher. You'll find it. Good luck! Gary
Twilight Fenrir
09-22-2015 06:52 PM
TexasGuy001
01-07-2006 10:01 AM
Elendil
03-28-2003 07:42 PM
