Speedometer Cable Question
I have a 1953 F250 with a 302 4-speed OD transmission. From what I can tell it retains the original rear end but the tires are now 4" shorter then the originals. The question is: Is there a speedometer cable that will work with the original speedometer and how do I calculate which gear to use. Thanks....Steve
I used to have that same tranny. Actually the stock cable may work as long as it reaches the hole on the tranny. As far as the gear goes you will need one with less teeth. Figure out how far off you are before throwing gears at it by testing with a GPS or a phone app.
Here is a formula for you.
Speedometer Gear Calculator and Charts - TCI® Auto
coppertales
10-06-2015 10:49 AM
RadioControlGuy85
12-12-2012 04:55 PM
69WestCoastFord
06-30-2009 07:40 PM
cjfaber
01-07-2006 08:07 PM
fordranger68
13
02-29-2004 10:56 PM
