Speedometer Cable Question - Ford Truck Enthusiasts Forums
Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign In
Register Forgot Password?
Old 03-30-2015, 07:00 AM
Steve49841 Steve49841 is offline
Steve49841 is starting off with a positive reputation.
I have a 1953 F250 with a 302 4-speed OD transmission. From what I can tell it retains the original rear end but the tires are now 4" shorter then the originals. The question is: Is there a speedometer cable that will work with the original speedometer and how do I calculate which gear to use. Thanks....Steve
Old 03-30-2015, 11:26 AM
truckeemtnfords truckeemtnfords is offline
truckeemtnfords has a great reputation on FTE.truckeemtnfords has a great reputation on FTE.truckeemtnfords has a great reputation on FTE.truckeemtnfords has a great reputation on FTE.
I used to have that same tranny. Actually the stock cable may work as long as it reaches the hole on the tranny. As far as the gear goes you will need one with less teeth. Figure out how far off you are before throwing gears at it by testing with a GPS or a phone app.
Here is a formula for you.
Speedometer Gear Calculator and Charts - TCIŽ Auto
__________________
Dave
2002 F-250 XLT 4x4 7.3 Auto CC LB
1955 F-100 302 T-5 9"
Old 03-31-2015, 07:13 AM
oldfordcoupe oldfordcoupe is offline
oldfordcoupe is gaining momentum as a positive member of FTE.oldfordcoupe is gaining momentum as a positive member of FTE.
a speed o cable # is ca3010 it is 83 in long but will fit to a c4 or what ever got it at o Riley
Old 04-01-2015, 06:25 AM
As usual...great help from FTE. Thanks guys, I will check it out.
Similar Threads
Off Topic Speedometer Cable danlee Clutch, Transmission, Differential, Axle & Transfer Case 0 08-04-2014 07:23 PM
Speedo Compatability 4tl8ford 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 03-07-2014 09:48 PM
Still having speedometer problems... kd7ptn 1987 - 1996 F150 & Larger F-Series Trucks 3 04-11-2011 06:59 AM
Speedometer is not working rashanny 1948 - 1956 F1, F100 & Larger F-Series Trucks 24 03-31-2011 11:14 PM
calibrating mechanical speedometer high ho silver Super Duty & Heavy Duty 1 02-27-2007 12:02 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.8.7 AC2
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
vbulletin Admin Backup
