BF Goodrich All Terrain tire size for stock 2008 20" rims?
03-29-2015, 08:15 AM
on
Hi, what would be the size tire(BF Goodrich All Terrain) I need to put on my stock 2008 20" F250 rims?
Thank you.
03-29-2015, 12:20 PM
on
The same size that's on there now... Hahaha
I did a quick search for the tire size, and it seems like 275/65-20 is the size you need.
03-29-2015, 01:05 PM
on
These 2008 rims are going on a 2006 truck.
Thanks for the info!
03-29-2015, 01:25 PM
I thought the 2008 and newer rims did not fit on the older 1999-2007 SD trucks??
Or was it the other way around with the older not fitting on the newer??
biz
03-29-2015, 02:06 PM
on
It is the other way around. Brake size is larger on the later models.
03-29-2015, 03:31 PM
Later model wheels also have a huge offset. Spacers are often required.
03-30-2015, 10:06 PM
on
Cleveland, how much offset am I looking at? Spacer size? Truck otherwise stock.
03-30-2015, 10:14 PM
I'm not sure exactly. But a 1.5"-2" spacer is what I've seen used on several applications, partly depending on tire choice.
03-30-2015, 10:16 PM
Actually though, 06 and 08 might be compatible as is. 05+ had a major offset compared to the first gen super dutys. I don't know if they changed it from 07 to 08.
Rusty_Old_F250
01-31-2013 07:52 PM
markusmoisi
11-02-2012 10:14 PM
kalamity kate
11-01-2004 06:36 PM
fishin machine
Offroad & 4x4
03-19-2004 09:41 AM
beefcake_431
08-02-2001 01:43 PM
