Lariat outside temp not working
Hi, I'm new to the forum, and have received much support by lurking around searching the posts, now I need help again... My outside temp always reads -40. I have a 2002 f350 Lariat 4x4 CC SW/SB 7.3L, I replaced the sensor behind the grill, still no luck. I traced back the wires and there are no wear marks or rub through that i can see. Is there any way to test with a multimeter? Any help or suggestions would be great. Attached is a pic of the overhead console all other functions on the console work fine. - Thanks, Pete
Or, the resistors are loose and need re-soldering, like so many others have reported.
https://www.ford-trucks.com/forums/4...ne-out-11.html
if it's only the display I'll leave it, and keep out of the dealer. if it would affect other truck functions, i'll consider it. as I mentioned in my orig. post all other console functions are working normally
I had an issue with my overhead display acting up. I took it apart and sure enough, the resistors had to be re-soldered. About a 30 minute job from start to finish. Not an issue since. Saved some bucks too!
RockyMtnRanger
05-01-2006 12:28 AM
