Removing Fuel injector from a 5.8L ??
The injectors are held in between the fuel rail and manifold, sealed with O rings on each end. You should be able to remove the bolts holding down the fuel rail and just pull it off of the injectors, then pull the injectors out of the manifold. Of course, pull the electrical connectors off the injectors first. You might want to get replacement O rings for the injectors if they're really old or hardened.
on
First vacuum as much dirt off the lower intake as possible, then spray some WD40 around the bottom of the injectors, remove the 4 bolts securing the fuel rail to the lower manifold and gently pry up on the rail, the injectors will either come off with it or the rail will detatch from the injectors at the top. With that out of the way remove any remaining injectors by wiggling and applying more lube, corrosion and dirt may make some of them stubborn to remove. The lower portion of the intake manifold isn't painted from the factory, degrease it and sand or bead blast it to really clean it up, and use a small wire wheel on a dremmel to clean up the injector bores which will make reinstalling them much easier. Apply some petrolium jelly to the injector 0-rings to make reassembly real easy.
Nasty stuff ? Really ???? I've used it for years to lube o rings on 1850 Holley balance tubes. And to lube the injector rings. Nothing nasty about it. You're not pouring gallons into the intake tract so there's nothing to worry about there. It's the perfect medium to lube O rings, that's what it was made for to begin with.
rsmack
11-09-2004 01:09 PM
