Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Super Duty & Heavy Duty
Sign in using an external account
Register Forgot Password?
Super Duty & Heavy Duty 1999 to current Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines SPONSORED BY:
Snapped both front u joints
Old 03-28-2015, 02:33 AM
Jxltrucking Jxltrucking is offline
Jxltrucking is starting off with a positive reputation.
I have a f-350 6.0L with 37s that I had a spool in the front with 38s and I recently switched to a powertrax lock right for the obvious turning problem. went out 4x4ing and snapped both u joints in the front and I replaced them when I did the locker any reasons for that or upgrades to stop it in the future?
Old 03-28-2015, 03:38 AM
99f350sd 99f350sd is offline
99f350sd has a good reputation on FTE.99f350sd has a good reputation on FTE.
Only use spicer brand life units..And go easy...
__________________
99 F350 5.4 Lockers,Warn winch,Hubs..MDII Plow, 200 amp alt timbrens,Revo's.2 24 " LED bar lights
THREE 96 aero*awd 4.0 ext. GREEN,BLUE,WHITE.Blue for parts//rust
2010 SUZUKI SX4 AWD CVT NICE
USAF 76-80
CX500 TURBO ORIG OWNER
Old 03-28-2015, 06:41 AM
Tom's Avatar
Tom Tom is offline
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
TomB985
Which brand joints did you install? Sounds to me that you put a LOT of stress on your drivetrain and may have used inferior parts.
__________________
Tom,
Currently truckless.
Most recently: 2013 F150 XLT 4x4 EcoBoost
Moderators, Guidelines, and How They are Enforced
Old 03-28-2015, 08:59 AM
dave7200 dave7200 is offline
dave7200 is gaining momentum as a positive member of FTE.
I can’t believe you snapped both u-joints. I used to snap the front joints back in my mud racing days. What shocks me is that’s a Dana 60 and that should be able to take most anything a 38 can throw at it. You must have really been pounding on it. I think your only option is RCV axle shafts for the front end. If you’re not familiar with them google RCV and check them out. They are expensive but the strongest option you will find. I had them in my Jeep with a Dynatrac pro rock 44 and never had a problem. They don’t cause the jumping a U-joint does when you’re off roading hard or digging in mud or snow. They do not have a U-joint.
Old 03-28-2015, 12:05 PM
taking it easy isnt an option If I did that might as well stay on the highway and remove the front drive shaft but what I went through I would consider mild to what I have done with the truck when the axel was solid I'm not a rookie and I minimize wheel hop cause to avoid snapping axels but the parts I used were moog u joints
Old 03-28-2015, 04:36 PM
17 Oaks 17 Oaks is offline
17 Oaks is gaining momentum as a positive member of FTE.17 Oaks is gaining momentum as a positive member of FTE.
If you are snapping u joints then you are well on your way to cratering some axle shafts.
Did they both snap at the same place and time? Or did one go and later the next one go.
U joints are strong and if you snapped them and they were recently installed then my first thought is they lacked grease.
3 things destroy u joints"
1) worn and they get lose
2) high angularity stresses
3) and this is the rarest, inability to handle the torque application.
In over 50 years of off roading I have never cratered a u joint, I have had some that went bad that I replaced but never exploded one. I use OEM 1310's at the axle input/driveshaft side. Its what i call my fuse, its my weakest link and it take all the torque my driveline throws at it.
If you have any pics of your shafts and u joints I would like to see them.
You may have stretched trunnions which can allowing some rocking of the joint, I have seen this as the problem. Often snapped u joints only leads to bigger and stronger, then repeat with bigger and stronger. Becomes a cycle.
__________________
Don
'15 F 350, CC, LB, Dually, King Ranch, Tuxedo Black. Garbage Truck Backup alarm.
'11 F 350 Dually Lariat Ult - SOLD
'09 F 350 SRW Lariat Ult - SOLD
Old 03-28-2015, 07:25 PM
redford's Avatar
redford redford is offline
redford has a spectacular reputation.redford has a spectacular reputation.redford has a spectacular reputation.redford has a spectacular reputation.redford has a spectacular reputation.redford has a spectacular reputation.redford has a spectacular reputation.redford has a spectacular reputation.redford has a spectacular reputation.redford has a spectacular reputation.redford has a spectacular reputation.
Did you post any video of the landing that snapped both u-joints?
__________________
2007 F-250 Super Cab Short Bed 4x4 XLT Sport Package 5.4L 3.73LS Tow Command
Stuart
Retired Master Sergeant
FTE Guidelines
Old 03-28-2015, 07:57 PM
ltlblutrk's Avatar
ltlblutrk ltlblutrk is offline
ltlblutrk is starting off with a positive reputation.
spool in front + 37" tires + dry pavement = broken something
Spools don't go up front on a truck that goes anywhere near pavement.
Good luck
Old 03-28-2015, 10:49 PM
Spicer life joints don't have grease fittings. Grease fittings weaken ujoints.
__________________
USAF 76-80
Old 03-29-2015, 08:48 AM
I agree with the last post. Grease fittings weaken the U-joint a lot. I’d still look into the RCV’s if I were breaking Dana 60 U-joints. They don’t wheel hop like a U-joint front end does making for smooth wheeling. No, I don’t work for them
Old 03-29-2015, 09:09 AM
Do grease fittings weaken u joints?
The answer is yes and no. From a pure view of a machinist we could say yes, as metal has been removed.
From the view of functionality, the answer is no. In fact they do not. I have seen a lot of broken u joints and cannot recall having seen one that was broken thru the zerk.
__________________
Don
Old 03-29-2015, 07:57 PM
ltlblutrk's Avatar
Quote:
Ditto................
Old 03-29-2015, 09:02 PM
The manufacturers claim that the greaseless are stronger. Has nothing to do with the zerk its the fact of the cross drilling to get to each end. Obviously less metal means less strength but I get what you guy's are saying.
__________________
USAF 76-80
Old 03-30-2015, 07:16 AM
JM96F250 JM96F250 is offline
JM96F250 is gaining momentum as a positive member of FTE.
Quote:
This is actually a fairly recent post on PBB
Longfield 60 joints (vote for redesign) - Pirate4x4.Com : 4x4 and Off-Road Forum
Click the image to open in full size.
Albeit not common, but it does happen. What was it you were doing at the time? Can we get a pic to refer to?
Old 03-30-2015, 02:42 PM
Longfield was a very small company that was bought out by Trail Gear in 2013 after the death of Bobby Long. I have no idea where Trail Gear has them made. They are also made from 300M steel, which is used in the landing gear of planes, BIG planes. Its tuff so and very difficult to machine. Clearly if it can handle the load of a Boenin 747 landing at 200 mph its not likely to break under some 5000 lb load.
I read thru the thread, looks like that breakage is not rare for this almost $300 u joint.
Close inspection of the pics shows a couple of things: The grease tunnel appears to be going into a much larger opening and right below I also see what appears to be a large opening that should not be there.
The the break itself seems to be following a same-same pattern across their u joints.
This tells me, no, it screams there is a internal problem from either casting or machining. I think casting IMO.
I ran Spicer 1310 OEM on Jeeps with D 44 axle and never had a breakage, nor did I ever see a breakage that was not a result of u joints that were already beginning to fail.
The off road market is more based upon faulty engineering than anything else. I mean do we really need $300 buck u j made from 300 M steel. There is a badge of honor that runs strong in the off road arena "I broke my 300 M u j", or "I snapped the axles in a Rockwell axle set". Most breakage on the trail comes from one or both of the following: Abuse and or FAIL of preventive maintenance.
I kept the undercarriage of my off road rigs spotless and after every outing I spent a good deal of time underneath looking for the telltale signs that a component was going to fail.
I used to lead runs out to Moab and we only ran 3+ - 5 rated trails, the most difficult. I watched rig after rig fail out on the trail...many of them professionally (?) built. One client trailered in his new Jeep which had over $50,000 worth of work done on it....426/425 hemi and the list goes on and on. It failed less than 50 yards into Pritchett Canyon. He took it into town, found a shop and $4k later he meets us and the other end of P-Canyon, again he broke but did make it almost 100 yds, so guess it was progress. I stayed in touch with him and a year later his new jeep was still not working and he was over $75k (not including the cost of the Jeep) in to it. Last I heard from him he was going to part it out and sell it.
__________________
Don
Similar Threads
Help outer U -joint Jim Hunt 1994.5 - 1997 7.3L Power Stroke Diesel 3 08-01-2010 07:03 PM
u-joint (HOW) 40LUTZAG 1997 - 2003 F150 8 05-05-2008 02:18 PM
96 Front Axle U-Joints clings89 Ranger & B-Series 4 01-28-2007 12:57 PM
broken u joint ????? blue96psd 1999 - 2003 7.3L Power Stroke Diesel 15 03-24-2005 09:36 AM
Spicer u-joints? blueoval79 Clutch, Transmission, Differential, Axle & Transfer Case 4 09-20-2002 10:20 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
