Stock Pitman Arm 79 Ford F150 4x4
I have a 77 Ford F150 4x4 that I am converting to a 78/79 steering linkage. I have not been able to locate the 79 pitman arm that I need. I have checked with all the local junkyards and no luck. Ebay only has drop pitman arms. The part number is D8TZ-3590-B. Any help would be great.
Is this it?
BDS Ford Bronco/F150 Pitman Arm (PS) 1978-1979
That doesn't look right... I think that's for an F250. Either the pic or the description is wrong.
I am in the same situation. I have a low mileage 76 F150 4wd which I would like to change the steering from the inverted Y to the later (78-79) T-style steering but cannot find a pitman arm. Anyone have one they would like to sell? I get what I hear is called the death shake when I hit a pothole or bump and am trying to do whatever it take to control the problem. My truck is NOT lifted. Any other thoughts? Help.
Applications: 1978/79 F150 4WD Regular Cab & Bronco / No Ford dealer or obsolete parts vendor has any.
Check with Bronco Graveyard and see if they have it, as it's the same.
Note: 1978/79 F150 4WD Super Cab uses a different pitman arm: D7TZ-3590-C (marked: D7TZ-3590-GA) / Obsolete.
It's the same as 1977 F250 4WD from serial number Y20,001 (not a High Boy), 1978/79 F250 4WD & 1979 F350 4WD
cayce73f100
10-21-2012 09:47 AM
Ken2600
03-25-2003 01:08 PM
