Bendix vs Saginaw shaft size
Is the splined output shaft that the pitman arm bolts to different in size or spline count than the later Saginaw box? The reason I ask is I found a Saginaw box on an F350 with the C7TA-3590-L pitman arm still hooked up.
I would like to get that box but the info. I found here and on Fordification site says that arm won't fit a Saginaw box. I was looking at it and took pictures which are on my post below.
Is this box modified or the arm or will it just fit? They had it working somehow? Is the info. out there wrong on this arm NOT fitting a Saginaw box?
Thanks
Thanks
balingwire
02-10-2014 08:04 PM
okedokeno
28
10-26-2012 10:45 PM
thatK30guy
10-22-2012 11:45 AM
ZombieSlayer
06-19-2004 08:15 PM
