Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1973 - 1979 F-100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
F250 2wd gears
Old 03-26-2015, 07:16 PM
frigerator's Avatar
frigerator frigerator is offline
frigerator is starting off with a positive reputation.
F250 2wd gears
Hey folks, I have a 75 CC, 2wd, 390, manual 4speed w/ granny and 4.10 rear end gears. My tires are 29.5 tall so it don't take long till the RPMs are making me want to shift to fifth gear which I don't have. I found a posi with 3.5 something rear end gears. Would that be to much of a jump. It will be towing a 22ft camp trailer during the summer months.
__________________
Dallas
Old 03-26-2015, 07:49 PM
Jdeshler's Avatar
Jdeshler Jdeshler is online now
Jdeshler has a good reputation on FTE.Jdeshler has a good reputation on FTE.Jdeshler has a good reputation on FTE.
I highly doubt that's too far of a jump with a 390 4 speed.. I'm sure there's someone here who can answer out of experience ..
Good luck
__________________
~James
99 f350 4x4 7.3 dually..........71 Chevelle 454
66 f100 4x4 302....................64 C10 283
79 f250 supercab 351m.......78 f100 300
51 Chevy wrecker.................48 john Deere model b
Old 03-26-2015, 10:48 PM
frigerator's Avatar
Thanks Fred, I'm hoping it will work
__________________
Dallas
Old 03-26-2015, 11:23 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to beholdHIO Silver is a splendid one to behold
Let this table be your guide?
Click the image to open in full size.
Old 03-26-2015, 11:54 PM
frigerator's Avatar
Thanks Silver, I could always get shorter tires. Cheaper to get smaller tires than taller ones. If it was a 4x4 I would go bigger
__________________
Dallas
Old 03-27-2015, 03:22 AM
Zack88's Avatar
Zack88 Zack88 is offline
Zack88 is starting off with a positive reputation.
I think you will be fine with the torque an FE makes, I ran 4:10 gears and 33's behind one with a 4 speed and still needed more gear. Swapped to 3:55 and loved it with a 29 inch tire.
Old 03-27-2015, 11:39 AM
ShaneNP123's Avatar
ShaneNP123 ShaneNP123 is offline
ShaneNP123 is starting off with a positive reputation.
Quote:
You got that bass ackwards, A shorter tire will bring your RPM's up, a taller tire will lower RPM's
__________________
'79 F-100 2wd 300/T-18/D44
'80 F-150 Flareside 302/T-18/NP208 Dana 44 SAS
'55 F-250 360/C6
'92 F-Superduty 6.9/ZF5
'88 Ranger 2wd SWB 5.0/C4
'88 Thunderbird LX 5.0/AOD
Old 03-27-2015, 01:01 PM
frigerator's Avatar
Taller tires with the 4.10 and shorter with the 3.55. The rpms are to high at 55 with the 4.10s & 29 inch tires
__________________
Dallas
Old 03-27-2015, 08:26 PM
Blue and White Blue and White is offline
Blue and White is gaining momentum as a positive member of FTE.
For towing kinda heavy, I'd personally go with a bit taller tire and keep the 4.10's. With 31" or 32" tires it should handle speeds up to 70 or so and still tow well. Yes it the engine will spin a bit but can take it fine. My 78/400/4.10 does fine at 70 with 31" tires. I'm running 245/75/16 10 PR on steel wheels. Pretty close to 9.50x16.5" which was on the truck before the switch to 16's.
2 wd makes it easy to swap rears only if desired.
Old 03-29-2015, 09:57 PM
frigerator's Avatar
looking for a little better gas mileage also. Gearing is cheaper then tires
__________________
Dallas
Similar Threads
Zf-5 compatiblity wtroger Clutch, Transmission, Differential, Axle & Transfer Case 1 03-26-2015 10:45 PM
Tow Question brzehentmaier Expedition & Navigator 4 02-06-2014 06:19 AM
gear swap in my 2wd v-10??? rcnitrofreek Modular V10 (6.8l) 10 11-22-2010 09:11 AM
rear end Q's hamels4x4 1987 - 1996 F150 & Larger F-Series Trucks 15 06-08-2007 07:36 PM
ZF 5 speed and 4.10 rear end speed gear size? F 2fifter with a 4 sixter Clutch, Transmission, Differential, Axle & Transfer Case 5 04-12-2004 11:40 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
