Alternator upgrade issues.
I'm trying to go with a 100amp one wire alternator for my 1975 f250 4x4 with a stock 360fe. All of the alternators I have tried are to deep and the back of the alt hits the cylinder head. I need some direction on how to get this done. I've dug through posts and called a retailer or two and have not come up with anything better than going down to a OEM size 75 amp. I will be running a dump trailer and a pop-camper both with trailer brakes. Jim from Centech who is currently building me a new wiring harness almost insists on a 100amp to power everything at once. Some direction would be most appreciated.
Go with a 3G swap instead, you use a Ford alt that you can source out of a junkyard and it is rated 90 and 130 amps
https://www.ford-trucks.com/forums/9...g-upgrade.html
There are other threads all over the Dent and Bump side forums and even the Bulldog forums, just search
hail destroyer
08-02-2016 05:37 AM
docholiday72tx
33
06-28-2005 08:07 AM
