C6 Kickdown Cable or Rod?
Old 03-26-2015, 01:10 PM
JordanL91's Avatar
JordanL91
JordanL91 is offline
I went through the HowTo's and FAQs and didn't see anything about it...
I realized my C6 on my SWB has no kickdown or anything corresponded to it. Since everything is missing related to this is it better to go Rod or Cable? Also what is the procedure and how to get the correct ratios? Thanks in advance for the help guys.
Old 03-26-2015, 02:47 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,678 Likes on 1,356 Posts
Since you don't have anything, get what you can that will fit your engine. You didn't say what engine you had.
This kickdown for the c6 is not critical like the AOD linkage is. It needs to be free during most of the throttle travel, and then be activated when the throttle is wide open.
Old 03-27-2015, 08:33 AM
JordanL91's Avatar
JordanL91
Sorry have a 302, The floor of the truck is not insulated or even have carpet laid down. I feel the heat on my legs, is this normal? I was contemplating installing a Trans Temp Gauge to have a reading..
Old 03-27-2015, 01:54 PM
Franklin2's Avatar
Franklin2
Yes it's normal for it to get hot. It's not necessarily the heat from the tranny, it's also the heat from the engine and the radiator as air is flowing down underneath the truck from the fan.
Old 03-27-2015, 02:36 PM
bowtieman55's Avatar
bowtieman55
bowtieman55 is offline
You MAY already know about the factory kick-down, JordanL91. In case you don't or need an idea about how to hook one up, here are a few pictures. I've got a picture on my other computer of where and how it attaches at the C-6.
and this one is from Luke76, a member here.
Old 03-27-2015, 02:52 PM
JordanL91's Avatar
JordanL91
Yea believe me with those recognizable Valve coves you didn't need to reference him, Hes got the nicest valve covers on FTE! But the pictures help a lot, thanks bowtieman!
Old 03-27-2015, 03:58 PM
86f250-rs's Avatar
86f250-rs
86f250-rs is offline
im doing a lokar throttle and kickdown cable. heres mine before I adjust the kickdown cable:
and heres the c6 side:
Old 03-27-2015, 06:50 PM
bowtieman55
Stock kickdown rod in place on a C6
Old 03-28-2015, 12:56 PM
JordanL91's Avatar
JordanL91
Since I don't have a kickdown rod in place Bowtieman I might be forced to purchase the Lokar kit. As of right now it looks like my best bet!
Old 03-28-2015, 12:57 PM
JordanL91's Avatar
JordanL91
Thanks for the advice 86, this will probably be the route I'm going
hivoltj
04-11-2016 02:51 PM
86fn150
01-10-2015 01:43 AM
6T6Shorty
02-28-2007 01:30 AM
superswamper
05-22-2004 01:18 AM
Quick Reply: C6 Kickdown Cable or Rod?
