Problem after headgaskets
Old 03-25-2015, 10:23 PM
truckrider814's Avatar
truckrider814
truckrider814 is offline
I just had headgaskets(oem) studs, egr delete,oil cooler done on my 06 plus water pump cause the gasket blew. I have a sct livewire hooked up monitoring everything and tonight i noticed that the eot and ect's were way off. fully warmed up and rolling 65 Anywhere from 40*-50* out it was eot-156 and ect-172. Degas bottle was at the normal level.
Im also having issues with the fuel gauge. Every now and then the gauge will go to E and the miles to E will display ---. Turn the truck off and back on it works again. Im half assuming its the plug on the sending unit or the sending unit itself. Kind of looking for conformation there.
Im having trouble figuring out what the problem is with the deltas so any help would be appreciated.
Thanks
Old 03-25-2015, 10:35 PM
78fordman's Avatar
78fordman
78fordman is offline
How long were you driving?
Old 03-25-2015, 10:37 PM
truckrider814
Couple few hours
Old 03-25-2015, 11:06 PM
jswartz84's Avatar
jswartz84
jswartz84 is offline
156 EOT and 172 ECT isn't fully warmed up, unless sensors are bad. Check the cold soak temps of the sensors and report back.
Old 03-25-2015, 11:12 PM
WatsonR's Avatar
WatsonR
WatsonR is offline
And I'd change the t-stat.
Old 03-25-2015, 11:14 PM
mustang_309's Avatar
mustang_309
mustang_309 is offline
Thanks
After an overnight cold soak what do the ECT, EOT and TFT read? Should all read very close to one another.
Old 03-25-2015, 11:47 PM
truckrider814
I'll check em in the morning. An excuse my ignorance but what's TFT?
Old 03-26-2015, 12:51 AM
mustang_309
Transmission fluid temp
Old 03-26-2015, 05:30 AM
truckrider814
Eot-70. Ect-72. TFT-65
Old 03-26-2015, 06:34 AM
truckrider814
I just ordered a new 200* thermostat from XDP(only 56 bucks) So when that comes in i'll install it ive been doing more reading and realized the temps aren't getting to where theyre suppose to be and since i just had the gaskets and cooler done it's most likely the tstat.
Old 03-26-2015, 06:48 AM
78fordman's Avatar
78fordman
Do you have the BPD oil cooler? bad thermostat or not The EOT should be more than the ECT. The EOT and the ECT sensor are one of the same. Personally I would swap the sensors and see what happens.
Old 03-26-2015, 07:46 AM
truckrider814
The oil cooler is from Rudy's diesel
Old 03-26-2015, 01:11 PM
KIDkiser's Avatar
KIDkiser
KIDkiser is offline
Did you get the oem one or the sinister cooler with the master kit?
Old 03-26-2015, 01:32 PM
truckrider814
oem. Sorry should've put that
Old 03-26-2015, 02:03 PM
jsm180's Avatar
jsm180
jsm180 is offline
Thermostat should have been replaced with the head gaskets and water pump.
Quick Reply: Problem after headgaskets
