Transit Connect 2010+ Ford Transit Connect
2010 shifts hard once in a while
Old 03-25-2015, 07:34 PM
tommytulip's Avatar
tommytulip
tommytulip is offline
New to the forum. Recently bought a 2010 Transit Connect with a 125k on it. Bought it from a flower shop, Runs great and has had bunch of service done by the dealer over the years. Including transmission service's.
The other day in stop and go traffic it shifted hard into second gear and the little yellow wrench on the instrument cluster came on. After that one hard shift it ran fine the rest of the way home. Once I stopped and restarted it went out. Check for codes and no codes stored.
Did it again today and the only difference was the little yellow wrench light turned off while I was driving. Again no codes
Sometime it seems like it should shift sooner than it does. I let off on the gas a little and it shifts to the next gear. It always shifts smooth other than the hard shifting a couple of times into second.
My overdrive button on the shifter does not work. I can not turn off the overdrive.
Any thoughts would be appreciated.
Thank you
Old 03-29-2015, 03:07 PM
operating engineer's Avatar
operating engineer
operating engineer is offline
Trans & filter needs more changes then " book " says
Your sure the trans fluid & filter is fresh & clean ?
Old 03-30-2015, 09:00 AM
tommytulip's Avatar
tommytulip
Thanks for the reply.
Transmission filter and fluid have been changed recently.
Old 04-22-2015, 09:03 PM
tommytulip's Avatar
tommytulip
Figured it out. It was the output speed sensor. Got it online for about $45.00. Easy to replace and runs like a champ.
Old 04-22-2015, 10:01 PM
operating engineer
Thanks, Output speed sensor @ $ 45, you did well..
[QUOTE=tommytulip;15295202]Figured it out. It was the output speed sensor. Got it online for about $45.00. Easy to replace and runs like a champ.[/QUOTE thanks for letting others learn.....
hadam
15
08-13-2021 09:36 AM
DanCC4884
03-09-2019 10:25 PM
whatusername
05-04-2016 09:12 PM
dieselsubmariner
02-15-2015 10:05 AM
justin_brandstein
02-22-2009 10:08 AM
Quick Reply: 2010 shifts hard once in a while
