Driving Problems
So just so we're all on the same page, once you discovered the hub situation, and got the hubs to properly unlock, you're not getting the vibration? And you ARE getting it when you lock the hubs? If that's all accurate, next thing I'd try is remove the front driveshaft and take it for another test drive, hubs locked. If the nose/vibration persists, then it's front diff, axle shafts, front axle u-joints, etc. If no vibration, I would take that driveshaft to a driveline shop to check/balance it.
Also, did you confirm that BOTH hubs lock/unlock? I could imagine if one hub is locked and the other unlocked, you could have stuff like this.
Explorin
10-10-2006 11:43 PM
OC Ford
1997-2006 Expedition & Navigator
09-22-2005 06:21 PM
