I have looked all over the web and on this forum to find the dimensions of the bushings for our 64 F100 262 motor and trans mounts. Can anyone help. I would like to fab up some to send to my son in San Diego.
I just replaced the transmission mount and both motor mounts on my '65 F100 352. Total cost was under $20 from O'reilly Auto Parts in San Diego. I don't know about your engine, but my mounts bolted directly to the engine block, and there wasn't anything I would call a bushing.
These are rubber 'donut' shaped insulators (motor mounts), not bushings.
C & G Ford Parts in Escondido (30 miles north of San Diego) might have them, since they are the same: 1961/64 F100/250 2WD/4WD 223 & 262 I-6 and are available from Carpenter.
C1TT-6A061-C .. (1) Lower Front Insulator & (2) Lower R & L Rear Insulators / Reproduced
CARPENTER has 41 = 800-476-9653.
C3TZ-6068-D .. (1) Upper Front Insulator & (2) Upper R & L Rear Insulators / Reproduced
CARPENTER has 923.
Thanks. I found those. Still looking for the metal bushing or at least dimensions.
