mounting a winch
OH...yea, no way it would have been big enough without removing the seats. The idea was to be able to hold a rifle case in one of the drawers, and two drawers to be able to use it as a command post when we deploy...
Idea would be to run that mounting track along the top wood surface, bolted through, then strap the winch down using that. Track bolted to frame, frame bolted to base and truck...should be somewhat safe in a wreck, but I wouldn't carry it around daily unless deployed...would be a fuel drain I don't need and take up space where the wife would want to fill with - stuff.
You made a nice setup!
It looks like it will work well for years.
I like those gun vaults but really have a valid reason for one or the room. You look to have saved a ton of money as well.
You have a pto on your excursion? Did you swap in a truck transmission or what?
Ptos are great for commercial use. Use the engine power. Can pull all day. High speed, too. Not my first choice for stuck truck use because on most transmission ptos, you can't engage the pto with the truck in drive, which means your can't spin the tires during recovery to assist the recovery. I also have serious doubts about the ability to run a pto shaft from the transmission to the front bumper on an excursion. They are a tight squeeze in older trucks with way more room. The excursion just doesn't have anywhere for the shaft to go.
If you're dead set on using the pto you could run a pto hydraulic pump and a hydraulic winch. Expensive and a lot of work unless it's something you're gonna use nearly every day or you're using to make money.
For occasional stuck truck or sliding logs around, it's hard to beat the ease of install and low price of an electric winch. And they work great for those type of things.
The fab fours winch mount is a little cheaper. Not saying this is a good seller or price. But thus is at least what it looks like.http://pages.ebay.com/motors/link/?nav=item.view&id=221391734402&alt=web
Apparently fab fours will sell them directly for 470 with free shipping.
Will always he cheapest to make you own of course.
The fab fours winch mount is a little cheaper. Not saying this is a good seller or price. But thus is at least what it looks like.http://pages.ebay.com/motors/link/?n...734402&alt=web
#29
The tow hooks bolt on with three big *** bolts. I'd think you could use some 1/2" steel plate cut to about 4" wide by 8 or 10" long rectangular brackets, drill it out to the pattern of the tow hooks, and remove the tow hooks and bolt it in place, then weld or bolt your winch mount to that. If you bolt it on, drill the 1/2 plate on both ends and then run grade 8 hardware through the bottom plate of your winch mount, through the 1/2 plate brackets, and back into the factory tow hooks so you can retain them.
#30
