Brake booster upgrade
Hello,
I have searched the forums, and found a few very good and detailed write ups on upgrading the brake booster unit on a 79 f-150 to one from a 79 f-350 . It seems all of them upgrade the entire braking system (booster, master, calipers, and cylinders) as a part of the swap, to use the larger diameter system all the way around. Has anybody done just the booster/master swap? This truck stops very well. The only reason we want to use the f-350 booster is so that it won't hit the valve cover of the 6.9 diesel that we have swapped into it. Since the brakes are working well otherwise, it would be great use just the booster/master, but not if it leaves us with questionable brakes. Any experiences you can share are appreciated.
BTW, it is a f-150 short bed with no intention of trailering, etc.
junkyardjeff
07-07-2008 08:36 PM
jeffbarron97
10-07-2003 11:19 PM
