LS rearend fluid causing my problems?????
This is the thread I started this problem with. https://www.ford-trucks.com/forums/1...p-or-jerk.html and https://www.ford-trucks.com/forums/1...r-bearing.html. I took it to the dealer today and had the shop foreman ride with me. It is only jerking when it is turned, even ever so slightly. He said it felt like the limited slip binding. So I asked, "what did you do wrong? Did you put the wrong fluid or not enough fluid or what?" Well he couldn't answer and said the service writer and technician would let me know after they look at it. So it had no issues, then I get them to fix the leaking pinion seal and rear diff cover, and now it jerks from the rearend. Does this sound like it could be the problem? If so what did they do wrong?
You are so helpful. I was just searching for info on this site for it. That is what it sounds like to me. Could it have damaged anything in the few hundred miles I've driven it since they worked on it? I can't wait to hear what type of nonsense they come up with. One thing is for sure, since I have found a good local independent shop, it will never go back to the dealer for anything. This place is a joke. The receipt is in the truck but I think they charged me something like $150 for 6 quarts of fluid to go back in it.
When I did mine I used the Mobil 1 stuff that already has the modifier in it.
I got a little chatter on corners so I added a bit more till is was quiet. I think
that was about 2 oz total. Where I really was able to hear it was on a section
of road that had a series of "S" curves. So it was working the LS and it was
making noise. So add a bit and go drive the road till it stops.
Sean
Sean
Exactly. I asked the service adviser if they forgot to do it the first time and he just said, well it was on the invoice the first time. That's why I'm done with the dealer. I can talk to the guy who actually is working on my truck at the independent shop.
It really did not need that much but made a BIG difference in the "S" curves.
No more thunk and bump.
Sean
Maybe they'll give you some money back, that would be nice...
I found the receipt. 5 quarts of xy-75w90-qls oil for $90. So there is price gouging at its finest. No mention of the limited slip modifier on the invoice so apparently they didn't add it. I googled the oil and it specifically states that some LS differentials need the modifier "Note: For a complete drain and fill, some limited-slip axles require addition of Friction Modifier, Part Number XL-3. Refer to the Workshop Manual or Owner’s Guide". So I guess it was too much trouble to look it up. It is Rusty Eck Ford in Wichita. Their shop is a joke and it will never go back to them. This isn't the first time they have provided terrible service on my truck.
