Transmission overdrive problem
First thing is to be sure it's not an electric control issue with a code set.
The v6 is the old push rod style motor from earlier times so it won't fit the v8 bell pattern you have.
Don't try to sub another year v8 trans unless your sure everything is the same because as each year progressed they changed things to interface with advances in computer control, motor, trans control cabling and changeover to digital dash.
Good luck.
Good luck.
drexyl
01-27-2010 07:01 AM
