Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1987 - 1996 F150 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Severe shudder !
Old 03-22-2015, 08:24 PM
Adamazar Adamazar is offline
Adamazar is starting off with a positive reputation.
Severe shudder !
Hey guys . For the past few weeks my truck has had a light stumble on acceleration and been a bit sluggish . I checked for crossfire but didn't see anything until I looked through the fender wells where the plugs go into the heads I can see the ceramic lighting up . I replaced plugs and wires and it still doing it . Last night while cruising down the highway the truck started bucking and shaking violently and pulled over but nothing seemed wrong with the suspension . I drove it the rest of the way home without it happening . There is no codes coming up . I'm going to replace the coil tonight and maybe the fpr . Could this problem be torque converter related ? The tranny was rebuilt 40 k ago
Old 03-22-2015, 08:26 PM
Oh yeah . The trucks a 94 f250 4x4 with an e4od trans . 351w . Thanks
Old 04-26-2015, 04:20 PM
edtruck edtruck is offline
edtruck is starting off with a positive reputation.
Shudder Fixed -came from bad gas cap, not bad coil
I bought my '99 f150 with 110K on it a few months ago. It shuddered after heated up at highway speed when I would brake and slow way down for an exit or turn, and then try to resume speed, I'd get that rumble strip shudder for a while. No codes came up. My mechanic thought it might be the transmission, after a transmission service, the tranny guy said it seemed like misfiring/ probably bad coil. It came especially around 1500 rpm.
I had not liked the way the gas cap seemed to fit & could see it was not original. For $12 on eBay, I got a FORD cap specified for the '99 f150.
Two tanks of gas later--500 miles--and no more shudder.
Old Yesterday, 06:41 AM
MtTheJeffro's Avatar
MtTheJeffro MtTheJeffro is offline
MtTheJeffro is starting off with a positive reputation.
Does sounds like a real nasty miss. Start with your basics as you described, coil, dizzy cap etc. Run the engine in the dark with the hood open and see if anything is arching under the hook. Could be as simple as a burnt up wire somewhere that you're not seeing in the daylight.
__________________
1988 F350 Crew Cab Dually
7.3 IDI, ZF5 speed
Oh yea, it's black
Similar Threads
Glow Plug indicator light issue Tom Callan 1987 - 1996 F150 & Larger F-Series Trucks 1 04-19-2013 07:20 PM
headlight problem DARYLS88STANG 1997 - 2003 F150 10 12-02-2012 11:00 PM
Signal light LWolffe Expedition & Navigator 8 01-05-2011 11:40 AM
blown fuse 72soa 2007 - 2014 Expedition & Navigator 2 10-23-2007 04:23 PM
lost taillights,instrument lights, and wait to start lt gbeach Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 1 09-10-2007 10:12 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
