Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Modular V8 (4.6L, 5.4L)
Sign in using an external account
Register Forgot Password?
no oil pressure
Old 03-22-2015, 03:17 PM
xcrmk xcrmk is offline
xcrmk is starting off with a positive reputation.
no oil pressure
Had my 2006 super duty with a 5.4l engine parked for around 10 days. Started it up and had zero oil pressure and it knocks just like there is no oil. Oil level is fine and it ran perfect before it sat for a little while. Any ideas about what it could be. There is 180,000 km on it. Oil has 3000km's on it. I changed the oil filter thinking it might be plugged but no difference.
Old 03-23-2015, 12:00 AM
07F150Lariat5.4's Avatar
07F150Lariat5.4 07F150Lariat5.4 is offline
07F150Lariat5.4 is gaining momentum as a positive member of FTE.
Shot in the dark here: I have seen a 5.4 3 valve engine do this once before. For absolutely no oil pressure, sounds like a crank thrust bearing may have fell off the crank and now the crank walks freely back and forth and is losing oil pressure. Maybe a sludged oil sump too.
How often is the oil changed? Is it clean?
__________________
2007 Ford F-150 2wd Lariat SuperCab 5.4L
Mods: Magnaflow SI/DO exhaust & aFe Stage 2 CAI
Old 03-23-2015, 04:01 PM
I change the oil every 6000km's usually. The oil is no more dirty than it usually is. Might try pulling the pan off to take a look and see
Old 03-23-2015, 09:34 PM
Most likely would be the best thing to do. I'm not 100% positive that is what it is, but I really can't think of anything else to make such a sudden issue. If the crank thrust bearing did come apart - you should see some metal pieces or shavings laying in the pan. Might even cut open the old oil filter (if you still have it but you probably don't) for metal shavings inside of it. Run a magnet over the pleats and if you find a lot of shiny flakes and it sticks to the magnet, most likely main bearing material.
__________________
Old 03-25-2015, 06:25 PM
Thanks for the info and help. It is fixed for now and seems to be working fine. I changed the filter and dumped the oil. Filled the oil pan with 5l of diesel along with a litre of tranny fluid and seafoam. Let it sit for 24hrs the started briefly for 10 seconds. Took about that for the oil pressure to jump up. Then ran for around another 10 seconds. Dumped the oil pan and filter filled with new oil and started. Oil pressure is right where it should be. Going to drive for a week and change again. Hopefully this has worked and no more issues. Thanks again.
Old 03-25-2015, 07:23 PM
No problem. Glad I could help. Sounds like a sludge issue. Sump is probably plugged. If that is the case; that's way better than a failed thrust bearing!
__________________
Similar Threads
P0420 code ???? StewB Super Duty & Heavy Duty 5 05-31-2015 08:11 PM
Fluid change intervals on 7k km/yr usage Zoltrix 1997 - 2003 F150 3 07-06-2014 11:13 PM
Overfilled engine oil (20 Liters (21 quarts)) Johnyjaq 6.0L Power Stroke Diesel 11 05-28-2014 07:57 PM
oil? Michel153 1987 - 1996 F150 & Larger F-Series Trucks 8 04-02-2014 10:45 AM
oil cooler dieselsmoker 6.4L Power Stroke Diesel 6 05-30-2013 07:47 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Participate In The Forums
Create new posts and participate in discussions. It's free!
Sign Up »
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2015, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Terms of Service - Jobs
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
vbulletin Admin Backup
