My 56 pickup build thread
#241
Received 4,115 Likes
on
#243
So runs are no big deal, just sand them out as long as they are in the clear coat and as long as there is enough clearcoat to sand? I know a guy who puts a piece of masking tape over a clear coat run and sand it until he gets down to cutting the tape, then removes the tape and blocks the area out until level. I should add a little to this. He does not stop sanding when it starts cutting the tape over the run, he keeps goin. When he gets to the tape level that starts showing on the level area around the run, he stops, removes the tape and finishes the blocking.
#244
on
#245
I have painted once so far. I used this method, and it worked very well for an inexperienced wet sander. Key here though is to catch runs in the color before you clear them.
#247
on
#248
on
Originally I was going to use the stock brackets and pulleys that came with this motor but was having problems trying to mount the A/C compressor so ended up purchasing these from CVF Racing but they are still not without alignment problems but think I have it solved now and need to measure up for my belts..
#249
on
#251
on
#252
on
#253
on
#255
on
