My 56 pickup build thread
  #691
Old 07-26-2018, 08:52 PM
topmoo's Avatar
topmoo
topmoo is offline
Well them days are long gone... lol
Well, at least you will soon have a really good front end..
  #692
Old 08-14-2018, 10:02 AM
F100wish's Avatar
F100wish
F100wish is offline
Hi John, Just finished going through the whole thread again (rather quickly) so forgive me if the answers are there. I have a few questions.
1) Your 351W motor mounts, did you make those or buy them...where? I am thinking about the TCI mustang !! coil kit.
2) With the TCI rear suspension kit, what pinion angle did you decide on?
3) Where did you get your rad shroud?
4) Did you use the Vintage Air kit?
5) Do you have the 2" drop spindles?
That is about it for now, looking at a 56 next week, wish me luck.
F100 Wish (aka Rob)
  #693
Old 08-14-2018, 01:36 PM
56panelford's Avatar
56panelford
56panelford is offline
Received 4,108 Likes on 2,642 Posts
1) I used Paul Horton's welder series kit for the motor mounts and were purchased at Street Rod & Restoration Parts - Horton Hot Rod Parts , I used a Heidt's superide ll coil over suspension almost Identical to the TCI
2) 5° for the pinion angle as the kit suggested
3) rad shroud was a stock V8 shroud I modified by trimming back approximately 3/4" and splitting in 2 halves
4) I used the Vintage Air sure fit kit ,made my own dash extension and bought different defusers
5) spindles are stock height which leaves the bottom of the front bumper 9 inches from a level floor..
  #694
Old 08-14-2018, 06:55 PM
F100wish's Avatar
F100wish
F100wish is offline
Hi John.
Thanks for the prompt reply. The 5 degrees I assume is down from pinion to back of diff, is the trans also 5 degrees down at the tailshaft? How did you figure out how high to start with the engine mounts?
Thanks again,
Rob
  #695
Old 08-15-2018, 08:50 AM
56panelford
I didn't set the rear pinion angle until most of the truck was put together and set the pinion angle 5° up at the pinion then welded the spring saddles to the axle shaft housing. Figured out the motor mount position by blocking up the motor and trans in place and giving enough clearance for the steering rack. I went with 3° down with the tail shaft..
  #696
Old 08-15-2018, 08:57 AM
F100wish's Avatar
F100wish
F100wish is offline
Thank you for the information. Will be posting pics once I get the truck, ship it, and start it.
  #697
Old 08-24-2018, 12:17 PM
F100wish's Avatar
F100wish
F100wish is offline
Any experience or heresay about this kit?
NarrowCrownVic
  #698
Old 08-24-2018, 01:29 PM
56panelford
I don't but sure someone on the site does. I put a Heidt's superide ll in mine..
  #699
Old 08-24-2018, 02:09 PM
fordslut's Avatar
fordslut
fordslut is offline
I posted some pictures of this awhile back when I found out about it, but I was to far along into my narrowed crown vic front end. I did buy their sway bar though. I just made the mounts and got it installed. I do wish i had seen the crossmember earlier though. it looks well made. I would have bought it I think. look up industrial chassis cross member while you're looking. another nice piece.
  #700
Old 10-01-2018, 09:17 AM
56panelford
Had the pickup appraised last week and got the paper work yesterday, it was appraised at $74,450
  #701
Old 10-01-2018, 09:39 AM
jniolon's Avatar
jniolon
jniolon is offline
old and in the way
Hi John... interesting Appraisal... was that from a private appraiser ?? What do they look at ?? do they take into consideration the custom things you did ?? did it have a positive or negative affect on our insurance rate ??:
cost for appraisal ???
thanks
john
  #702
Old 10-01-2018, 10:12 AM
67nukeford's Avatar
67nukeford
67nukeford is offline
Damn! worth every penny! I need to get our 39 Ford appraised.
  #703
Old 10-01-2018, 11:31 AM
underthebridgejim's Avatar
underthebridgejim
underthebridgejim is offline
FTE fan
Rite on John, its nice to see that all your attention to detail and beautiful workmanship, was recognized in the appraisal.
  #704
Old 10-01-2018, 03:18 PM
truckeemtnfords's Avatar
truckeemtnfords
truckeemtnfords is offline
Is that Canadian or US dollars? If that is Canadian then 58,000 US is still outstanding.
  #705
Old 10-01-2018, 04:18 PM
EBEAR's Avatar
EBEAR
EBEAR is offline
That's great John but my guess ( experience laden ) is that you are getting less than minimum wage for your work .
Quick Reply: My 56 pickup build thread
